What is this connector?
Old 04-28-2012, 03:21 PM
1bad03snake's Avatar
Default What is this connector?
There are two of these on my harness and I'm not sure where they go.
Old 04-28-2012, 03:46 PM
Beyond Static's Avatar
knock sensors
Old 04-28-2012, 03:54 PM
Rick Speed's Avatar
Knock sensors they plug in under the intake to the sensors in the hidden holes in the valley pan.
Old 04-28-2012, 07:46 PM
I have an 04 so my connector is different. Can I tie these together and buy the right connector to make it work with my setup?
Old 04-28-2012, 09:04 PM
LS1Tech Sponsor
psiconversion's Avatar
Not sure how you mean they are different. They were the same until GEN IV engines when the knock sensors were located low on either side of the engine block and featured 2 wire sensors instead of 1 wire.
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old 04-28-2012, 09:45 PM
My knock sensor harness is black and flat with a metal tab. I have two of the oval ones connectors coming off my stand alone harness
Old 04-28-2012, 09:59 PM
Bullitt4110's Avatar
That plug is for the knock sensors in the valley.
Old 04-28-2012, 10:02 PM
Ohh nice i get to pull my intake off... thank you for the info. This is my first ls swap.
Old 04-28-2012, 10:42 PM
brian.harmon1974's Avatar
Its not that bad to pull the intake. Its 8 bolts and as long as the gaskets aren't junk you can use them again. Then the knock sensors r right there
Old 04-29-2012, 01:06 AM
the_merv's Avatar
10 bolts for an Intake..
Old 04-29-2012, 09:31 PM
I got the sensors hooked up, are those covers needed? I plugged them in and put the intake back on. I guess I should be careful about water getting in the holes
Old 04-30-2012, 12:19 AM
the_merv's Avatar
There wasn't a black cover on them wires?
Old 04-30-2012, 04:47 AM
I'd run the covers. Over time the knock sensors will start to corrode from water getting trapped in there
Old 04-30-2012, 07:03 AM
LS1Tech Sponsor
If I am assuming correctly you are talking about those black plugs that snap into the valley pan. Yes, I would run them, keeps stuff from getting to the knock sensor holes.
Jon
PSI
__________________
Ebay Store
Old 05-01-2012, 09:44 PM
Rikoshay's Avatar
They actually slow down the water that gets down into the holes. LOL
Old 05-01-2012, 11:12 PM
the_merv's Avatar
Ya.. Doesn't let it come back out..lol
Quick Reply: What is this connector?
