Crank bolt - LS1TECH
Conversions & Hybrids LSX Engines in Non-LSX Vehicles
Crank bolt
Thread Tools Search this Thread
Old 04-29-2012, 09:30 PM   #1
dmracing's Avatar
Default Crank bolt
Whats the easiest way to remove it. Ive tried an impact and breaker bar. Any tricks?
dmracing is offline   Reply With Quote
Old 04-29-2012, 09:56 PM   #2
aknovaman's Avatar
Bigger air impact wrench with more torque.
aknovaman is offline   Reply With Quote
Old 04-29-2012, 10:07 PM   #3
Bullitt4110's Avatar
Hold the flywheel and a big breaker bar. My 1/2" drive snap on impact usually doesn't even break them loose.
Bullitt4110 is offline   Reply With Quote
Old 04-29-2012, 10:21 PM   #4
If its not moving, get a longer bar or a bigger gun.
I've had luck with other cars by wedging the bar against the floor and bumping the starter.
i r teh noobz is offline   Reply With Quote
Old 04-29-2012, 10:26 PM   #5
bczee's Avatar
I use a 4' pipe on the end of the breaker bar.. Have been able to break loose any thing i've run across.
BC
bczee is offline   Reply With Quote
Old 04-29-2012, 11:11 PM   #6
-TheBandit-'s Avatar
Just make sure you're using a strong breaker bar! I have snapped a couple 1/2 inchers in the past.
I've used the starter bump trick a few times in the past with success. Just be very careful with that one.
-TheBandit- is offline   Reply With Quote
Old 05-01-2012, 10:49 PM   #7
The factory bolt has red loctite on the threads. I went to Harbor Freight and got an electric impact gun and sat there for a minute banging on it before it budged. Applying heat helps.
Rikoshay is offline   Reply With Quote
Old 05-02-2012, 12:11 AM   #8
the_merv's Avatar
Pull your skirt up and give it hell..
Some of them are in there..no joke.. I have a good 1/2" breaker bar with a 3' cheater bar.
the_merv is offline   Reply With Quote
Old 05-02-2012, 12:16 AM   #9
I use a 2' breaker bar with a 3' jack handle. The leverage is really easy at that point.
merim123 is offline   Reply With Quote
Old 05-02-2012, 01:33 PM   #10
kainedogg's Avatar
My motor was on the stand, wedged a huge screwdriver in the flexplate (be careful not to bend it) then took my $7 Harborfreight 1/2" breaker bar and attached a 18" pipe to it, and voila, it came off. Getting the pulley off is another matter itself.
kainedogg is offline   Reply With Quote
Old 05-02-2012, 02:18 PM   #11
Using the right tools makes the job a lot easier.
Flywheel stop to hold the motor is a nice tool:
I made one
If the engine is in the car and you have a manual, you can lock the ebrake and put it in a high (5th/6th) gear to keep the engine from rotating.
Then use a cheater bar for removing the bolt
And a3-jaw puller for getting the pulley off
Here you can see where the jaws should be pulling from - there are three recessed areas cast into the pulley for this purpose.
Old 05-02-2012, 06:28 PM   #12
dmracing's Avatar
Its on a stand, my fault
Old 05-02-2012, 07:03 PM   #13
Your fault???
Old 05-02-2012, 07:14 PM   #14
the_merv's Avatar
You can bolt at piece to it while it's on the stand..
Old 05-02-2012, 07:41 PM   #15
boostit5.3's Avatar
i've never seen a tool like that gonna have to pick one up..
boostit5.3 is offline   Reply With Quote
Old 05-02-2012, 10:11 PM   #16
wesmigletz's Avatar
Quote:
Any idea who sells them?
wesmigletz is offline   Reply With Quote
Old 05-02-2012, 11:03 PM   #17
the_merv's Avatar
I've seen them on summit..
Old 05-02-2012, 11:36 PM   #18
wesmigletz's Avatar
Quote:
Thanks
Old 05-03-2012, 12:48 AM   #19
Heat the head of the bolt long enough so the heat tranfers down the bolt. Heat will loosen loctite or any thread sealer. I work on alot of Harleys and they loctite everything and that always works.
builder1 is offline   Reply With Quote
Old 05-03-2012, 12:58 AM   #20
waterbug1999's Avatar
Quote:
Originally Posted by builder1 View Post
Heat the head of the bolt long enough so the heat tranfers down the bolt. Heat will loosen loctite or any thread sealer. I work on alot of Harleys and that always works.
X2.. I fought with it for hours one time, put a little heat to it and it came off with a a little tap of the 4lb shorty sledge..
waterbug1999 is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
delete CyberGrey Z28 Parts Classifieds 3 05-06-2014 11:06 PM
Sold jetaws6 Parts Classifieds 13 05-06-2014 02:37 PM
Sold!! jeremyfrank14 Parts Classifieds 0 04-08-2014 09:30 AM
test 396375 2016 LTX Shootout 2 03-11-2012 10:18 PM
Tags
390, 53, bar, bc, bolt, bslancer, cheater, crank, crankshaft, ford, jobs, ls2, powered, reusing, stock, vbulletin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
