Which O2 Sensor for a 2002 6.0 Truck Motor?
Old 05-02-2012, 10:28 AM
Docked Wage's Avatar
Default Which O2 Sensor for a 2002 6.0 Truck Motor?
The 6.0 Engine is from a 2002 Youkon Denali. It came with the harness and the ECM. The ECM # is 12200411
The problem is the butcher who removed the harness chopped off the whole transmission section so the O2 sensor plugs are missing.
I went to the GMC dealer and they said it could be one of 2 connectors. Can anyone point me in the direction of an O2 sensor that will work with the PCM? From there I can back into which connector pigtails I'll order.
Thanks, Ken
Old 05-02-2012, 11:33 AM
LS1Tech Sponsor
psiconversion's Avatar
4 wire Black square or 4 wire black flat are the most common for the 411.
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old 05-02-2012, 12:16 PM
sawzall wielding director
G-Body's Avatar
Either connector style o2 sensor will work they both put out the same voltage range. IIRC the flat vs square connector style difference depends on which plant that truck was built in but I can` remember which plant used the flat connector and which was the square.
Old 05-02-2012, 12:57 PM
Yes, the dealer did mention it could be flat or square depending on where it was built. I'll go with the square black ones.
Any recommendation on which part number O2 I should use?
Old 05-02-2012, 02:49 PM
Old Geezer's Avatar
"Any recommendation on which part number O2 I should use?"
Regardless, I'd check $$ B4 I got hammered at the dlr.
Quick Reply: Which O2 Sensor for a 2002 6.0 Truck Motor?
