1969 chevelle ls swap - LS1TECH
Conversions & Hybrids LSX Engines in Non-LSX Vehicles
Thread Tools Search this Thread
Old 05-04-2012, 12:37 AM   #1
Default 1969 chevelle ls swap
I am new to this and have look at a lot of your post and looking for help .What is the best kit to buy to put a 6.0 with a 4l80 trans in.Headers mounts I am not someone that can fab stuff this is why I am looking for bolt right in type of kit I do not want to cut the frame fire wall trans tunnel up . This car has been a frame off car I can up with it with no motor or trans just like some help on were I can all the parts in one time thank one
barber33 is offline   Reply With Quote
Old 05-04-2012, 01:28 AM   #2
Bullitt4110's Avatar
You'll probably have to modify the tunnel some to fit the 4l80 as it is pretty big. I have Car Shop INC. 1" set back plates, energy mounts, and an autokraft pan and I was able to leave the frame stands in the factory location as well as use factory holes in the frame for the trans crossmember. This is also in a 69 Chevelle. I also have the Dougs swap headers and they seem to fit great with lots clearance.
Bullitt4110 is offline   Reply With Quote
Old 05-04-2012, 10:11 AM   #3
thank you so much
Old 05-04-2012, 12:27 PM   #4
No problem, just remember every car is different so it still may require a little bit of tweaking to get it work. But with the amount of clearance I have everywhere Im pretty sure you could get it work.
Old 05-04-2012, 01:01 PM   #5
andrew69_04's Avatar
I've used the transdapt mounts in all my swaps. only mounts that I had problems with were the hooker mounts in a 69 camaro. Also for headers, I've been using the Dynatech swap headers. The fit and quality is great and i've yet to have a set that didnt fit. for $400 shipped, the price is also nice!
andrew69_04 is offline   Reply With Quote
Old 05-06-2012, 08:46 AM   #6
oldgoat69's Avatar
As the others have stated each one will be a bit different. I have used the following combination. All fit like a glove. In any event you will have to make room for the 4L80E, and the crossmember will need to be modified.
Frame mounts #3379 www.carpartsdiscount.com
Headers Dougs
Engine adapters Dougs SK100
Motor mounts Energy Suspension 3-1117G
If you are using truck accessory mounts you will most likely need to change PS pulley to Dorman 300-123.
Don't waste time with the truck pan, it wont work out well. I used Canton 13-274 with pickup 13-275 and filter mount 22-631.
There are a host of others as well that won't require cutting the k-member.
I can supply pictures if you are interested.
oldgoat69 is offline   Reply With Quote
Old 05-06-2012, 04:45 PM   #7
Headers Dougs
if you could supply pictures would be nice thank you
Old 05-06-2012, 05:25 PM   #8
oldgoat69's Avatar
Here are a few random pictures. Remember, this is only a short list of the stuff you will need. Do you already have the engine and trans?
Old 05-06-2012, 05:28 PM   #9
oldgoat69's Avatar
Attachments don't want to load, I will try again later.
Related Topics
Thread Thread Starter Forum Replies Last Post
LS2 turbo with nitrous T/A need help NCTRNLBLKBIRD Forced Induction 3 01-20-2013 07:08 PM
Feedback on my motor mounts jozw30 Conversions & Hybrids 9 07-25-2011 11:20 PM
ls1 going into 77-79 trans am? ls1ssws6 Conversions & Hybrids 9 08-06-2007 08:42 PM
Can a bent frame be fixed and hold up to 1000 rwhp with 25.2 cage???? ebaker Pontiac Firebird 1967-2002 2 10-28-2006 11:51 PM
Tags
1969, 2012, 4l70e, 69, chevelle, engine, fit, headers, ls, ls3, swap, transmission, truck, work, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
