mcleod aluminum flywheel
Old 05-14-2012, 11:29 AM
Colin Frolick's Avatar
Default mcleod aluminum flywheel
hi everybody
i found this ad and bought one of these today. plus it's the Al model, i didn't even know they made one.
i called mcleod to order it and the price is real!
http://www.racingjunk.com/Clutches/1...el-Chevy-.html
Cheers!
Old 05-14-2012, 03:44 PM
usdmholden's Avatar
What's the downside of the +.400" thickness?
Will a stock type clutch still work?
Old 05-14-2012, 04:15 PM
garys 68's Avatar
If you're doing an LS conversion with an old school trans, Muncie, T10, TKO, Richmond 5/6 speed, etc, the 0.400 inch moves the disc back so the splines dont run off the front of the trans input shaft.
I dont know if the hydraulic throwout bearing on the LS1 T56 can be shimmed back enough to use this flywheel though.
Old 05-15-2012, 08:34 AM
usdmholden's Avatar
Then that's a great deal if it works with the setup. I don't see it working with my T56, but that's why I asked.
Old 05-15-2012, 09:19 AM
speedfreak90's Avatar
that's excellent info.
Quick Reply: mcleod aluminum flywheel
