TR6060 to a 5.3
TR6060 to a 5.3
Need advice on mating a 2010 camaro tr6060 to a 5.3. I think the input and bell housing are slightly different than a t56. Camaro flywheel? What pilot bearing? Thanks
You have to use the 2010 camaro slave cylinder and pilot bearing. The bellhousing to block is same as LS1 style T56. TR6060 has integral bellhousing, T56 has bolt on bellhousing. Input shaft has same splines, but TR6060 is longer. Clutch wise, the splines are the same and the flywheel teeth are the same, so you can technically go with any factory LS style T56 or TR6060 clutch/flywheel. Not sure my statement is true for aftermarket equipment. The 2010 camaro clutches are the same as the LS7 clutch. You can find them in great shape lightly used for dirt cheap. Paid $125 shipped for mine.
The following users liked this post:
Homer_Simpson (09-21-2023)
Thanks
I knew the input was a little longer and the bell a little deeper on the TR6060, but wasn't sure if it all worked out the same. I got a great deal on the trans, (still need to pull it down and check everything), so now I can pull the rest of the parts together.
The only thing I had to buy was a fitting to adapt the S10 style line to a braided line to run the trans. I don't see why you can't try the same, It's a lot easier to mount the clutch master that's meant for your truck then adapting one.
Same setup fo 0bs chevy
Tr6060 to 5.3
Im just about to mount tranny on to the 5.3 i have the flex plate from the 5.3 that came with the engine with that work with the oem clutch that came with tranny off a 10 camaro ss. My question goes to the bolts that were for my 4.8 clutch kit thakitsed to mate my old nv3500 are 2 short to re use on the canaros cluth kit am i suppose to get longer ones or buy a different flywheel?? School me.
