4.8L LR4 swap into 04 Colorado Clutch line help (same as T56 LS1 clutch line fittings
Old 05-21-2012, 02:13 PM
94camaroz28lt1's Avatar
Default 4.8L LR4 swap into 04 Colorado Clutch line help (same as T56 LS1 clutch line fittings
Need to make the clutch line longer and reroute it, comes into contact with my header. The slave cylinder is the same as the T56 with a LS1/LS2. And the fitting going into the master looks like the same as well.
Problem is most adapters to AN line I have scene on the clutch slave, make you remove the tranny and salve then drive out the roll pin holding the quick disconnect fitting in place, and then install the adapter fitting. I don't want to pull the tranny out! Someone must have a quick disconnect adapter fitting to AN?
Quick Reply: 4.8L LR4 swap into 04 Colorado Clutch line help (same as T56 LS1 clutch line fittings
