radiator overflow tank
Old 05-22-2012, 05:31 PM
crosstraining's Avatar
Default radiator overflow tank
Are the stainless steel tube shaped radiator overflow tanks any good?
It looks like it has a return side, which is what I want.
Here is one:
Old 05-22-2012, 06:37 PM
JIMB's Avatar
Try Speedway Motors. I've used two wih good sucess. Various sizes as needed.
Old 05-22-2012, 08:10 PM
Pop N Wood's Avatar
I spot welded a couple of brackets onto a stainless steel water bottle and that is what I use for an overflow bottle. Bolted it right to the Taurus fan shroud. Drilled a hole in the plastic lid and ran the overflow tube to the bottom.
Massively cheaper than the expensive stuff sold for that purpose and works perfectly.
Old 05-22-2012, 08:26 PM
john 67's Avatar
plenty of them on e bay. JOHN
Quick Reply: radiator overflow tank
