Someone tell me what a Corvette cooling fan PWM module is...
Old 05-31-2012, 01:39 PM
samckitt's Avatar
Default Someone tell me what a Corvette cooling fan PWM module is...
And can the GMPP LS2 controller kit be wired to control the fans through this module.
Thanks
Old 05-31-2012, 05:26 PM
TurboS10's Avatar
PWM is used for speed control. Freguently GM uses it for on/off.
Looking at the vette wiring diagram may tell you how it's used.
Old 05-31-2012, 07:39 PM
samckitt's Avatar
I have searched the net for a pic of this animal with no luck. Anyone have one?
And can someone point me to a Vette wiring diagram?
Thanks
Old 05-31-2012, 11:50 PM
71403's Avatar
Search and ye shal receive
https://ls1tech.com/forums/conversio...ns-please.html
Old 06-01-2012, 06:59 AM
samckitt's Avatar
Ah grasshopper. Thanks for the information. Now I gotta figure out if I can have the GMPP controller ECM reprogrammed to send the proper signal to this module, and possibly control two fans.
Old 06-16-2012, 09:54 PM
68sixspeed's Avatar
Doesn't the gmpp control have the variable speed function built in? I've only been running mine a week butim pretty sure the speed is variable and I was able to force low/high on with HP tuners. Dan
Old 06-17-2012, 09:02 AM
samckitt's Avatar
I though 3 relays were needed to run in high/low speed, my GMPP controller only has one relay for the fan. Assume that is for on/off, havent got it running yet.
Old 06-17-2012, 04:57 PM
68sixspeed's Avatar
I'll plug in with HP tuners again later and test it to be sure..l
Old 06-21-2012, 09:05 PM
68sixspeed's Avatar
Scot- you are correct, 1 speed only. I flipped between low/high during the startup of the motor and didn't even notice it was all the same.
So, back to the top... any way to make the control the fan speed better?
Old 06-24-2012, 05:57 AM
68sixspeed's Avatar
Scot, FYI, it looks like HP tuners or EFI Live won't change the program tables for th fan relay on the gmpp harness, so the fans can't be turned on until ~203 degrees. So while researching, I found this, might be a good option, although it does require a 20-25 degree split between the low and high settings. Might be ok though with a 170/175 low and 190/195 high set points. (for a 160 thermostat)
http://www.spal-usa.com/fans/automat...es/fanpwm.html
Old 06-24-2012, 06:43 AM
samckitt's Avatar
I saw that one from Spal, there is also one from Painless wiring I saw that also has speed sensor input. So if going over x mph, the fans are shut off & air from moving forward goes through the radiator. Also, a fellow gearhead close to me said that Ed Hutchins is working on getting the GMPP controller to work with the PWM fan setup as well as he is working on a cruise control setup for the GMPP controller too. I haven't confirmed this yet.
Old 06-24-2012, 07:55 AM
68sixspeed's Avatar
Excellent, keep us posted on what you find.
On the cruise, there is a kit made already, $499 when I called to check, http://spankysrodshop.net/
Old 06-24-2012, 11:12 AM
samckitt's Avatar
A budy of mine got the one from Spanky's, he has to have the computer reprogrammed because his VSS output is WAY off. He is using the GMPP controller kit too. If it can be done with the computer in the controller kit, I would prefer doing it that way.
Old 06-24-2012, 09:40 PM
68sixspeed's Avatar
I noticed the gmpp "vss" setting is defaulted at 40 pulses per rev and it should be 17 according to Tremec. 50mph on my speedo is 20mph on the computer. I hate to waste 2 credits on hp tuners to activate it and change the vss though. (since I can not get the fan setting down either)
Old 09-10-2013, 11:06 AM
samckitt's Avatar
Forgot about this thread, have been having the same conversation over on Lat-G:
http://www.lateral-g.net/forums/showthread.php4?t=40215
I have my E67 GMPP controller wired up with the single wire to the PWM module, and a 3 wire circuit to the AC pressure switch, supposedly this is all that is needed for the PWM fan control setup. Ed Hutchins said the GMPP controller can be programmed to control it too. So (one of these days) I will get it running & get it to him to program all this up. I have to order/buy the Corvette fan/module setup & install on my radiator.
Quick Reply: Someone tell me what a Corvette cooling fan PWM module is...
