Brake switch mod for 72 Cutlass
What are you guys doing for you brake switch for your swaps. I want to add cruise when I do my LS1/4L60E swap into my 72 Cutlass, and I heard you will need to switch or mod your brake switch. Some people use a relay but I have seen some take a brake switch from a newer Camaro or other vehicle. What Vehicles can you get one from that will work for a 72 Cutlass? This Camaro one looks pretty similar to my stock on except for the extra connectors. Are these much simpler to swap in and rewire? Thanks in advance.
When I added cruise control to my 66 GTO I used a AC Delco switch part number D850A it is identical to the brake switch I have in my 69 chevelle except for the extra set of terminals, I am sure it will work in your 72 Cutlass as well.
I got it from Amazon for around $10.00 it is a direct fit and has 2 set of terminals, 1 set of terminals is normally open for your your brake lights and the second set of terminals is normally closed for your cruise control dis-engagement.
I was able to swap in the switch from an 02 Z28...i think that is the same one you have picture. I am not using the Cruise Control. But I was able to just swap it, just about a direct replacement. I wired up the Brake Light switch and use one of the other sets pin for the TCC.
But as you note. I just added the correct terminal for the TCC and build a short harness to convery the terminal/pin for the Brake Light. I will have to use some relay to make sure I give the PCM the correct ground or power. If you research you will find what other have done. there is a sticky on connecting the Cruise Control.
follow my link in my sig for my Nova project, Page #5 and post #85.
BC
BC
Mid 80s GM brake switch for auto, available at Autozone. One terminal NO (brake lights), the other NC (TCC/cruise).
http://www.autozone.com/autozone/acc...er=612872_0_0_
With the 6 pin switch, you would wire the TCC and IGN(12V) to one set of rear pins but do you know if you would wire the cruise with the TCC wire on that pin or use the other pins for cruise and IGN? And is it IGN(12V) that you would pair with cruise just like the TCC?
So looking back at some wiring diagrams, there is a LT Blue wire that goes to the brake pedal switch for a +12v signal for Cruise to work, you tie that in with the Lamp side of the N.O. Brake Lamp section of the switch so it will receive voltage when you press the brake pedal. Is this right?
And to hook up the TCC, you use a +12V keyed source to on terminal on the N.C. side and then the TCC wire to the other terminal? I'm going to go to a Salvage yard this weekend and look for a 4 pin brake switch. If I can't find it I'm going to stop by the AZ by work and order one.
Thanks garys 68. I'll hook it up that way. I picked up a 4 pin switch from an 82 blazer yesterday. I also found a universal cruise control switch from a late 70's Ford that mounts on top of the turn signal lever. Is there a way to find out if its a NO or NC switch? I read that it makes a difference.
kevmac- TCC(Torque Convertor Clutch) switch is only for auto's. You don't need it wired if you have a Manual but you should need the Clutch Switch wires if you want to have cruise.
Bad news, ford uses NC cruise control switches. The GM ecu needs NO switches. I bought a generic from Dakota Digital and found out the hard way. You can wire with relays or try to find a GM that will work for you.
I used the DD ford style switch. Turns out there is a momentary closed lead from the resume wire when you hit set, if I remember correctly. So I wired that to the "set". The only functions that work on the stalk are the on/off ans set, but I'm ok with that.
