Motor mounts for LTx --> LSx conversion?
Old 06-13-2012, 10:47 AM
TWS
TWS's Avatar
Default Motor mounts for LTx --> LSx conversion?
I have already done a bunch of reading and have come across contradictory info (some say they work, some say they have tried it and it doesn't)
So, I am throwing this out here hoping to get some ground truth to avoid buying parts that won't work/don't fit.
I am thinking hard about putting an LSx motor in my '94 Z28. I have an aftermarket LT1 K-member already (Pro Fab if that matters), are there adapter motor mounts that really work that will allow me to install an LSx motor?
I read about one member who tried it and despite the alleged "adapter" mounts, it didn't work.
If there is a set out there, that would be great as it would allow me to avoid purchasing an LS1 K member. Thanks in advance.
Old 06-13-2012, 03:29 PM
Mr. Hyde's Avatar
I like where this is going.
Old 06-14-2012, 11:39 AM
jlaudioholic's Avatar
I was going this route too @ 1 point, but found a stock k member locally for dirt cheap. Being that you had already shelled out a grip a cash for the tubular k I know you dont want to go that route. In the research stage of my LT to LS swap I found a place that had plates for this swap. Google 'dirtydingo' swap plates. They even have sliding and adjustable plates. Sorry to the powers that be if tey are not a sponser.
Old 06-14-2012, 01:09 PM
TWS
TWS's Avatar
Thanks man. I actually have a spare stock LS1 K member, but can't stand the thought of making the car heavier by putting it in place of the Pro Fab tubular, so I am going to check out your suggestion.
Old 06-14-2012, 05:17 PM
the_merv's Avatar
The normal swap plates don't work in this case.. I think it was a 1" forward mount that is needed..
Old 06-14-2012, 05:24 PM
TWS
TWS's Avatar
I think it was your thread I read where you tried it unsuccessfully. I'm going to call the source mentioned by jlaudioholic and talk to them... see if they have a set that will really work.
Old 06-14-2012, 08:38 PM
the_merv's Avatar
Yup.. I tried and it was a no-go..
Quick Reply: Motor mounts for LTx --> LSx conversion?
