Mustang LSX Swap K-Member Question
Old 06-18-2012, 10:17 PM
otherjohnson's Avatar
Default Mustang LSX Swap K-Member Question
I'm looking for ways to cut costs on an LSX swap into a 98 mustang, and I am trying to figure out what the cheapest K-member combination would be. I did do a search, but I couldn't find anything conclusive.
I was thinking: 96-98 4.6 GT factory k-member, UPR LSX adapter plates, and Corvette factory exhaust manifolds.
Will this combination lead to rubbing or interference?
Old 06-18-2012, 10:22 PM
Also, I was going to use an f-body oil pan.
Old 06-18-2012, 11:27 PM
94'BLKBRD's Avatar
I used an '04 4.6 k-member and made my own steel plate adapters.
Costed me $10 to make the adapters.
K-member and mounts -$80
Motor mount adapters-$10
Labor- Free
$90 is dirt cheap compared to the $400+ I was going to spend on the AJE stuff.
Old 06-19-2012, 07:20 AM
boostnut's Avatar
I'm not sure if the vette manifolds will fit. I picked up a set of 2010 camaro manifolds, they fit my 95 mustang like they were made for it. You can usually get a pair for $40 or $50 on the camaro forums.
Good luck.
Old 06-19-2012, 03:22 PM
Thanks for the input!
94'BLKBRD - Are you using an f-body oil pan and f-body factory exhaust manifolds?
Boostnut - Are you using your stock 5.0 k-member in your combination? Or did you go with a 4.6 factory k-member?
Old 06-19-2012, 03:40 PM
| Powered by Satan |'s Avatar
Also curious to know, although my car already has a maximum motorsports tubular K-member.
I would hate to have to sell/part out any more stuff beyond the stock longblock to free up some cash to build up a lsX for the car.
Old 06-19-2012, 03:55 PM
bfurches's Avatar
Check out my build thread
https://ls1tech.com/forums/conversio...n12-works.html
...exactly what you want to do...cheap with an f-body pan!
Old 06-19-2012, 04:32 PM
Yeah, I think i'm just gonna build my own brackets to work with my MM tubular K-member.
Old 06-19-2012, 06:43 PM
94'BLKBRD's Avatar
I'm using a truck pan and truck manifolds facing forward(turbo setup)
Old 06-20-2012, 08:41 AM
boostnut's Avatar
I'm using the AJE k-member. It was cheap, easy, and saves a bunch of weight right where it counts. If I had it to do all over I'd use a different tubular k-member, the MM unit looks like a really nice piece.
Old 06-20-2012, 07:16 PM
lebedin8654's Avatar
I keep going back and forth about this same subject I am trying to do the swap on a budget but its hard to do with some many options out there.
Quick Reply: Mustang LSX Swap K-Member Question
