need advice please someone help
Old 07-10-2012, 10:19 PM
Lawrence2012's Avatar
Default need advice please someone help
ok so i recently picked up a cheap 84 gt turbo fox body even though im a gm guy i love the fox bodies. i found a ad on craigslist for a ls6 and t56 for $3800 was said to come out of a 05 vett with low miles. id love to do the swap and they say anything is possible but what worries me is the wiring and what all is needed in the swap. Im currenty a wyotech student (which by the way is a joke the commercials LIE!!!!!) and not alot of money floating around. id like to do maybe a single turbo. what do yall think? anyone done this? how hard is it? i know i will have to have a aftermarket k member and all that good stuff any advice is help thanks
Old 07-10-2012, 10:34 PM
spacemanspif's Avatar
Better be VERY low, and documented miles for that price. And should also come with the computer, wiring harness, gas pedal and FEAD (water pump, alternator, power steering pump). Wiring is not that difficult and new "stand alone" ones can be had affordably if you decide its too much of a hassle. lt1swap.com has TONS of info on how to mod your harness yourself. Search the site and you'll find out that the Fox mustangs are probably the most swap vehicle.
Old 07-10-2012, 11:01 PM
it comes with the following ls6 t56 intake injectors and bracket new plugs and head gaskets throttle body clutch bell housing ecm ac hoses and canaster alternator and maf and ecm no harness i cant find one with a t56 any cheaper
Old 07-11-2012, 06:16 AM
spot_55's Avatar
I may be mistaken but don't the vetts still use the torque tube setup? If so the tranny will need to be converted to a regular tail shaft also.
Old 07-11-2012, 06:32 AM
garys 68's Avatar
The vette T56 is a transaxle, not practical to convert to a standard trans.
Old 07-11-2012, 07:19 AM
RNation0001's Avatar
yea i believe they were all transaxle setups, if not then someones giving you one out of a camaro, but for 3800 it better come with a harness, but its not that hard once u get into it, ive done two swaps now and ill do another as soon as i can find something to do it to lol
Old 07-11-2012, 07:34 AM
A-Dub's Avatar
Id be a big suspect of the for sale ad. No LS6 offered in Vette in 05. CTS V was the only way to get an LS6 in 2005. The V did have the traditional trans bolted to engine application, but it used a unique version of the T56. Not a deal breaker, but will make certain things a little tougher to find.
Old 07-11-2012, 09:32 AM
Well it looks like a regular t56 so it'll work and I've been reading but not finding any info on the wiring because I don't have the money currently to buy a painless kit unless y'all know where I can get a decently priced one or know someone who builds harnesses
Old 07-11-2012, 09:50 AM
Or a good cheap wiring harness
Old 07-11-2012, 10:49 AM
74novacustom's Avatar
PSI Conversion harness is the Cheapest ive seen.
Old 07-11-2012, 10:57 AM
Wil a ls1 2 3 or 7 harness work? Or does it have to be for a ls6?
Old 07-11-2012, 12:29 PM
LS1MCSS's Avatar
Well, first you need to know what reluctor the motor has. Look at the crank sensor and tell us the color of it. It's either black or gray. You will need to know what the motor has before ordering a harness.
Old 07-11-2012, 03:14 PM
It's black I'm almost positive
Old 07-11-2012, 07:16 PM
Pop N Wood's Avatar
If it has new head gaskets I would want to know why they were replaced.
that is a lot of money for that set up.
Old 07-11-2012, 08:47 PM
no he got new head gaskets still in the box along with some other parts was gonna tear it down and redo it the only other thing i can find any where close to where im living now is a ls1 and t56 high miles for 4850
Old 07-11-2012, 08:54 PM
and im looking for some turbos to throw on it to but not sure what all i can use on it
Old 07-12-2012, 07:02 AM
LS1Tech Sponsor
psiconversion's Avatar
If the crank reluctor is black then it is a 24x motor. You can run a camaro/firebird or Drive by Cable Vortec Truck harness. We have them if you are interested.
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old 07-12-2012, 09:04 AM
A-Dub's Avatar
Have you verified its even an LS6? Do you have some pictures? Post them up and we can help you out.
Old 07-12-2012, 09:14 AM
Yea but never posted any pics on here any help?
Quick Reply: need advice please someone help
