Anyone done a ls swap into a GTA?
Old 08-05-2012, 11:58 PM
RIP1976's Avatar
Default Anyone done a ls swap into a GTA?
Looking for some info from anyone that has done a swap an used a newer style 4l60e tranny an have a analog style 140mph speedometer. Will the vss in the newer trannys still work the factory electronic speedometer?
Old 08-07-2012, 01:53 PM
mille_3's Avatar
I'm going out on a limb here and assume you are talking about a 3rd gen firebird? if so then yes it will work.
Old 08-07-2012, 02:28 PM
RIP1976's Avatar
Yes I'm referring to the 3rd gen cars that had an electronic 140 mph speedometer. Jus need to be sure the vss in a newer 4L60e will supply the correct signal to operate it
Old 08-07-2012, 02:37 PM
bczee's Avatar
A GTA is a Firebird, A Firebird is a GM Gen Three F-Body Platform.. ====>>> Answer = Yes It has been done.
I am not sure of the Signal type or the number of pluses, but that can most likely be corrected by correcting the PCM's VSS output signal to match your Speedo.
BC
Old 08-07-2012, 03:21 PM
mille_3's Avatar
It will work just fine. Many of us have done it.
take a look here http://www.thirdgen.org/techboard/lt...ltx-swaps.html
Quick Reply: Anyone done a ls swap into a GTA?
