6.0 flywheel
6.0 flywheel
Hello, I want a flywheel for my LQ9 6.0 engine but, I don't find anything specific for the 6.0, does it take a special flywheel ? if not which one will fit ?
any suggestions on the best place to buy one ? I see some on E Bay for the 5.7 at a good price but will they fit ? I wasn't in to a $800.00 aluminum one.
just a plane old flywheel and pressure plate, thanks
Vern
Vern
They're all zero balance. I've used LS1 flywheels and clutches on mine. Note that the flywheel may be drilled for a specific pressure plate, ie LS1 vs 2 vs 7, etc, so buy a flywheel and pressure plate that go together.
The only exception is the GTO, it also requires the GTO T56 bell and starter.
