Ground wires
Old 08-09-2012, 03:39 PM
AB6DO's Avatar
Default Ground wires
Finishing up my stand alone harness from an 07 5.3 with 4L65E..I left the factory ground wires in their factory locations on the engine. I am thinking I will connect all the grounds to a bus bar and connect the bus bar to the battery ground post. See any problems with this set up?
Old 08-09-2012, 05:30 PM
74modified's Avatar
I am using one like this
http://i1159.photobucket.com/albums/...7222012210.jpg
But - You still need the block and frame grounded (heavy gauge) and a loop to your terminal block to the frame. You can never have enough grounds!
Old 08-09-2012, 05:47 PM
burbalanche's Avatar
with harrness grounded to block,block to frame and body to frame does the body need to be grounded to the block as well?
Old 08-09-2012, 05:57 PM
i r teh noobz's Avatar
Probably not, but it won't hurt. You can never have too much grounding.
Old 08-09-2012, 07:21 PM
74modified's Avatar
Yes, you would not want some high powered motor (fan, wiper, ect) to use your small ECM grounds as their ground path. They could overpower the small wires and burn.
Old 08-09-2012, 07:58 PM
99VetteFRC's Avatar
I have all the grounds from my harness tied together in the harness and hooked the top back of the block. My fan is grounded to the battery and the ground cable goes from the battery to the block. My battery is then grounded to the body and the engine is solid mounted to the frame. Plenty of grounds.
Old 08-12-2012, 04:19 PM
AB6DO's Avatar
Default Grounds
back to the top
Old 08-12-2012, 07:53 PM
Rocketrod's Avatar
What he said. All of my grounds will be tied back to the battery with the appropriate gauge wire/cable.
Old 08-12-2012, 07:55 PM
62n62's Avatar
you have clean grounds and dirty grounds, computer and sensers need clean grounds
Old 08-12-2012, 08:27 PM
rotor vs. piston's Avatar
Read my sig'
Old 08-12-2012, 08:48 PM
73AMC's Avatar
Can never have too many grounds. Make sure the areas the grounds are connecting to are clean.
Quick Reply: Ground wires
