Best auto fox shifter?
Old 08-10-2012, 09:45 PM
streetlegalls1's Avatar
Default Best auto fox shifter?
I'm in the last stages of parts hunting to start the ls1/th350 build on my coupe and would like some opinions on auto shifters,keeping in mind it will retain full factory interior
Old 08-11-2012, 08:25 AM
Chrome_Rust's Avatar
Just use the stock one. I am using a stock 99-04 shifter in my sn95 dash swapped mustang. I'm using a 4L60e though.
Old 08-11-2012, 12:11 PM
Thats an option i've thought of also but been looking at the B&M mega shifter and shifters like that for not shifting through a gear when i make passes at the track,but still looking for insight from others
Old 08-11-2012, 12:53 PM
Gray86hatch's Avatar
Hurst quarter stick. Holcomb motorsports mount.
Google it there will be pics. Mega shifter is a joke.
Tim
Old 08-11-2012, 01:28 PM
A friend has the quarter stick in his coupe and swears by it as well as others i see.I believe this is the way i will go except mounting it in the ash tray area,i have a spare i can modify
Old 08-13-2012, 07:59 PM
Old 08-14-2012, 12:37 AM
Nice office.Thats the way i will go.You have a nice set up,the hole car seems to work well
Old 08-14-2012, 10:41 AM
LS1PUNK's Avatar
Tim
The Holcomb mount will only work if ur car was a standard from factory.
Mine hits the top of the tail housing and Im running a short tail.
Old 08-14-2012, 11:18 PM
Builtz71's Avatar
I'm gonna look into that set up..looks nice,mine was a factory 5spd
Old 08-14-2012, 11:37 PM
MikeFSKSpeed's Avatar
Pistol grip quarter stick is an awesome way to go!
Old 03-04-2013, 07:32 AM
87lsttop's Avatar
My car was a standard from the factory that I converted to auto and removed the 5 spd hump. Went to th400 and replaced the hump and welded it in and using a holcomb mount it still hits the trans. No way around it.I had to install it in the ash tray area. Sucks as I wanted the interior of the car as stock as possible.
Old 03-09-2013, 11:32 PM
Ended up going pro stick in ash tray
Quick Reply: Best auto fox shifter?
