gas tank fumes
gas tank fumes
Hey guys,
My Nova is stinking up the house. I find it great, but my wife does not. The car is in the garage & when the AC kicks on it pulls the fumes inside.
Does any see a problem with capping my old vent tubes on the gas tank & getting a vented gas cap?
It is an orginal 1972 gas tank, with I think 1 vent line & 1 that I think went to a carcoal canister.
Thanks
Thanks
Have you checked to make sure it isn't leaking anywhere? I've seen tanks leak at the sender from a bad or incorrectly installed sending unit o ring, and you'll smell it, but it won't leak on to the ground since it's on top of the tank, and only comes out a little from the gas sloshing around while driving.
Another thing to check is what type of fuel line are you using, I used the Jegs cloth braided black fuel line and fittings and I too had real bad fumes. I switched out my entire fuel line with a steel braided TEFLON lined hose and it took care if my fumes completely.
I read you want to make sure if you are using hose that it is Teflon lined, and be careful gas fumes shouldn't be taken lightly if your house A/C is sucking in the gas fumes you have a electrical motor in your A/C unit which may create very small electrical sparks and coupled with your fumes, you have the recipe for a potential explosion.
My Ricks tank has a 1/4 nipple on the fuel tank neck and that just goes to a little stand pipe in my 66 GTO trunk.
I would find were your A/C unit its leaking air.
Were is the return air located as well as the unit?
If its in the garage then it might have a leak. I would make sure the inside of the return air is sealed off good, no gaps in for air to get into it other than through the filter.Seems to me dirty air is getting in the house.
Now it could be as simple as your door going into the garage is leaking air when the unit kicks on. Check the seal on it was well.
If the car had a charcoal canister I would hook it up and the EVAP system be easy enough to do. That would help stop the smell. But still need to find the reason for it getting into the house to begin with as that air leak is costing you money!
The next step will be to drop it down & see what is going on by the sender & the vent tubes.
The A/C unit is in the garage. It is a Geo thermal unit if that makes a difference.
How do you like your Rick's tank?
Thats not good to hear. I recently found out the Summit brand of twist-tite hose is no longer rated for fuel use. I've been planning on using the Jegs black nylon that you are referring to. I guess at least I didn't order it yet & the box of Summit hose and fittings are no good now.
I like the Ricks tank it is almost too pretty to put under the car, I got a great deal on it as I live in El Paso and they are local to me, I got to deal with Hector, he is Ricks father, and they have a nice shop and nice people to deal with. It is about the only part I was able to buy local and get a good deal on, everything I had to order and have shipped in. Oh the other thing I can get cheap and local are the tacos, but that's about it in this town.
We offer a small vent catch can with charcoal to keep the smell down.
https://www.nastyperformance.com/sho...tank-vent-can/
You well always get Gas Vapors.. you really need to use a Charcoal canister setup of some type if your drive and keep the car in the Garage that is connected to a House.
Using a Vented cap is not always the best solution. As the tank and fuel expand.. the vapors are going to want to excape.
As Nasty is marketing. It would be a good idea to get something in place. if the cost is too much. you can always hunt one down in the pick n pull and connect it up to the vent lines to let it filter the venting vapors.
BC
BC
BC
BC
I did not know about this. I will check into getting one.
resurrecting my thread because I finally getting around to the charcoal canister.
On a 72 Nova I see the tank has a feed & return line. There are also 2 other lines on top passenger side of the tank. Are they both vent lines? The lines go into the body. Does anyone know where they come out at? I want to run 1 line to a charcoal canister to reduce the gas smell. Can cap the other line?
Thanks
Thanks
