LQ4/T56 into 2001 BMW 540i
Old 03-22-2015, 09:03 AM
  #421
LQ4-E39's Avatar
^Absolutely. You need to employ the same tactics she uses on you - constant persuasion over time (such as her nagging for a new sofa set or carpet). Recently I was browsing C5 Z06 prices just to see where they were, and she says "You can have one of those if you get rid of the BMW." And only a few years ago, any fast toy would have been out of the question!
Old 04-20-2015, 11:02 AM
  #422
LQ4-E39's Avatar
So, some spring updates. I replaced the overflow bottle as the old one was discolored, replaced the kidney grills with new ones, and raised/adjusted/leveled the coilovers.
Took the car to be tuned at New Era, Mike did a nice job, although it proved difficult to tune.
Drove it to work every day for a week and generally enjoyed it. Went to Rochester to visit a friend:
On the drive back, about 60 miles from home, I got a random miss that turned into a tap, which quickly turned into a light knock 30 seconds later
Got it home, pulled it into the garage, and we get this
Oil Pan Doritos
All caused by this
Spring broke, dropped a valve, valve met piston, broke the rod, and sent it through the pan and block. So, now I'll need a replacement block and heads - the valve made some big gouges on the inside of the combustion chamber - currently on the hunt for a dropout just like I had. The spring was a single beehive, PRC 1518 good to .600 (my cam is .588 on both intake/exhaust). I bought the cam, springs, and pushrods as part of a package deal sold by Texas Speed. Spoke to them and they will be replacing all 16 springs for me with a stronger set, along with other seals, seats, and retainers. Just kind of ironic since I only drove the car maybe 300 miles after putting it on the road...if it had happened just a few hundred miles sooner, it would have been late last year, and I'd have been able to spend all winter fixing it. But, it is what it is, so gotta move forward.
Day after the motor blew - 90 mins in
Another few hours on Tuesday got me here
Had a buddy stop by and help me "put it in storage"
So, it sits for now until I can find a new motor. I only had a chance to pull the one head, and it was trashed. Still need to put the motor on a stand and pull the pan and accessories/front cover to see if the lifters/cam survived.
Old 04-20-2015, 12:05 PM
  #423
Boost infection's Avatar
Dam all that sucks!!! I cant say anything but new build V2
Old 04-21-2015, 12:27 AM
  #424
mapleridge's Avatar
crappy, but it just doubled the entertainment of this thread to see another build. 2 for 1.
Old 04-21-2015, 01:20 PM
  #425
vazfx16's Avatar
I am so sorry to hear about this.
Good luck on the repair...Get all Steve Austin on it:
Old 04-21-2015, 01:50 PM
  #426
BudRacing's Avatar
Maybe you'll find an aluminum block this time
Old 04-21-2015, 02:29 PM
  #427
LQ4-E39's Avatar
$2,000 premium over an iron block for 80lbs savings and less displacement? no thanks. even an LS2 block, which would keep my displacement, is a Gen4 and not set up for my Gen3 harness. besides, the beauty of an iron block is cheap replacement in case of an "oops"...much like this one.
Old 04-22-2015, 07:53 AM
  #428
vazfx16's Avatar
Keep the cubes
Old 04-28-2015, 12:33 PM
  #429
LQ4-E39's Avatar
Which brings us to this past weekend. Was cleaning up the garage a bit on Sunday morning, on a whim decided to hop on the local Craigslist and do the usual search for "6.0". Lo and behold there was one locally for cheap, with a "slight knock", For my purposes, perfect! It came with some nice parts that will help recoup some costs. Loaded her up and had it home before noon. Not much info on the motor other than that it "came out of a steak truck" (LOL) and had aluminum 317 heads (so, it was at least a 2001+).
Yanked the intake and heads and checked bores, they looked great for unknown mileage.
Removed the remaining 15 valve springs at my super fancy cylinder head service bench. Wine and cheese come standard
Awaiting these LS2 full floating rods/pistons, should be here tomorrow - can't say no to more compression while I'm in there!
Tonight I'm borrowing a friend's engine crank to finally put the new motor on the stand. I had my old man drop off the power washer last night (and fixed a broken switch on it), so as soon as it's completely torn down, I will drag the block over to the neighbor's front yard and start cleaning it up.
Old 04-28-2015, 10:15 PM
  #430
BudRacing's Avatar
Don't sass me with logic and reason!
Old 05-05-2015, 01:36 AM
  #431
rbaksi's Avatar
Nice find on that block! I love your updates keep em coming!
Old 05-06-2015, 01:04 AM
  #432
StreetMachine82's Avatar
Awesome build(s)!
I'm doing an LS-6 in a '66 Volvo 122S.
Keep'em coming!
Old 05-06-2015, 02:39 AM
  #433
oldxr's Avatar
Caddy cts-v t56.You could cut and weld those bars on the shifter to adjust the position.It had that 3 bolt triangle output like a BMW.
Old 05-06-2015, 08:04 AM
  #434
LQ4-E39's Avatar
thanks for the tip...the remote shifter is a pretty cool idea but my angled offset rod has been working very nicely for me. the less bushings and moving parts, the better.
Old 05-06-2015, 04:10 PM
  #435
BudRacing's Avatar
Agreed. You do NOT want the V's shift assembly.
Old 06-04-2015, 07:26 AM
  #436
LQ4-E39's Avatar
quick update - between the day job and working on the car I am pulling some 16+ hour days here (and will be for the next week)
the good news is that things are moving right along with no issues (aside from misplacing my tube of RTV and spending 45 mins looking for it).
Tuesday 6pm, motor picked up from builder. Bottom end (crank, pistons, rods) assembled, otherwise a totally bare block
IMG_20150602_170056_314 by Norbert Ogiba, on Flickr
Tuesday 11pm
Block cleaned, masked, painted, all block coolant and oil plugs installed, oil tray on, cleaned and prepped oil pan/windage tray/pickup tube/oil pipes. Head dowels in. Crank and cam sensors in, along with valley cover and knock sensors. Had to call it quits as I was waiting on the oil barbell plug and a new timing chain. I love Summit Racing
IMG_20150602_220307_082 by Norbert Ogiba, on Flickr
Wednesday 11pm
New timing chain installed and motor timed (LOL), cam bolts loctited and torqued. Oil pump installed, oil pickup tube inspected and installed (don't screw up that o-ring!) Rear cover and main seal installed, balancer pulled on to align front cover and main seal, both covers aligned and torqued. Oil pan and accessories installed, sealed and torqued, alignment checked. Deck surface cleaned, headgaskets and heads installed and ARP bolts torqued in sequence to spec. Wrapped up the night by installing and torquing 8 new spark plugs.
IMG_20150603_221917_087 by Norbert Ogiba, on Flickr
I am taking a ton of pictures with my other camera for documentation's sake but don't have time to make my usual very long winded post so those will have to wait until a few weeks from now
Old 06-09-2015, 10:49 AM
  #437
LQ4-E39's Avatar
Cylinder Head Cleaning and Reassembly
Since one of my 317 heads was trashed from the bent/broken valve in the initial mishap, I decided to go down a different route with heads and grab a used set of 241s locally - they were very clean, low mileage, and the price was right. Although they don't technically flow as well as 317s, I was willing to give them a try since I did not have to mill them to bring up compression.
The heads came assembled with stock springs and valves, but the previous owner had installed a set of stud-style rocker mounts (with loctite), so I spent an evening with a handheld MAP torch coaxing them out.
IMG_20150530_200448_163 by Norbert Ogiba, on Flickr
Before pictures - heads were removed from a 2002 Pontiac Trans Am with 50,000 miles.
_DSC3835 by Norbert Ogiba, on Flickr
_DSC3836 by Norbert Ogiba, on Flickr
I cleaned all surfaces with a rag and isopropyl alcohol to remove grease and dirt, and then ran a plastic scraping tool over all surfaces to remove the last of the old gasket material. They came out looking very nice.
Bare valve seat base
_DSC3838 by Norbert Ogiba, on Flickr
Seats installed
_DSC3839 by Norbert Ogiba, on Flickr
Brand new PRC dual valve springs with Titanium valve retainers.
_DSC3841 by Norbert Ogiba, on Flickr
Installed using my homemade spring compressor.
_DSC3842 by Norbert Ogiba, on Flickr
Before and after cleaning service on the heads, all done by hand. I actually really enjoyed this part.
_DSC3844 by Norbert Ogiba, on Flickr
The heads came out really nicely in the end. Of course I installed all new GM OEM valve seats and seals in addition to the dual springs and Ti retainers. The factory valve locks were in good shape and were reused.
_DSC3850 by Norbert Ogiba, on Flickr
Old 06-09-2015, 11:14 AM
  #438
LQ4-E39's Avatar
Engine block cleanup and paint
Bottom end came back from the machine shop on Tuesday June 2nd, so I jumped right in.
_DSC3854 by Norbert Ogiba, on Flickr
_DSC3855 by Norbert Ogiba, on Flickr
Unwrapping the goodies
_DSC3856 by Norbert Ogiba, on Flickr
Flat-top piston goodness. My builder oiled the motor lightly to prevent flash corrosion on deck surfaces
_DSC3857 by Norbert Ogiba, on Flickr
Up on the stand, degreased, taped, and ready for paint
_DSC3858 by Norbert Ogiba, on Flickr
I had a set of nasty looking front and rear covers laying around, so rather than tape off those areas, I just snugged them up with 2 bolts to keep the paint out of the internals.
_DSC3859 by Norbert Ogiba, on Flickr
_DSC3860 by Norbert Ogiba, on Flickr
I chose a high high engine primer to start with, followed by medium gray high heat engine enamel. The idea was a nice "clean" color that would make leaks easy to spot, and not draw too much attention. I was going to go with an aluminum alloy silver, but since this is an iron block, it wouldn't have looked "right" on the porous iron texture.
_DSC3861 by Norbert Ogiba, on Flickr
Certainly won't win any concourse awards but I like how it came out.
_DSC3862 by Norbert Ogiba, on Flickr
Oil pan was welded up by a local shop and got a fresh coat of silver aluminum color paint.
_DSC3863 by Norbert Ogiba, on Flickr
Old 06-09-2015, 11:53 AM
  #439
LQ4-E39's Avatar
Bottom End Assembly
Scat I Beam Forged Rods, ARP hardware
_DSC3868 by Norbert Ogiba, on Flickr
_DSC3870 by Norbert Ogiba, on Flickr
The stock crank was in good shape, so it was reused - rod journals were within clearance and were just polished, but the mains needed to be ground .010 with appropriate size Clevite "P" bearings installed.
_DSC3872 by Norbert Ogiba, on Flickr
_DSC3873 by Norbert Ogiba, on Flickr
_DSC3874 by Norbert Ogiba, on Flickr
Ready for the oil pan.
_DSC3875 by Norbert Ogiba, on Flickr
A new oil galley barbell plug was installed as the old one's o-ring had grown brittle and dry.
_DSC3876 by Norbert Ogiba, on Flickr
A new OEM GM LS2 timing chain replaced the weaker factory Gen 3 chain.
_DSC3877 by Norbert Ogiba, on Flickr
I have to find the pictures, but I also disassembled the stock oil pump and scrubbed every component. Nothing special to report besides the typical oil staining and deposits. The pressure relief spring was not stuck, but I still cleaned the spring bore to make sure it moved perfectly.
Oil pump was installed over new timing set followed by front and rear covers, which each received a new main seal. Oil control tray, was installed followed by the pickup tube (don't pinch that o-ring!). Lastly the balancer was pressed on using my homemade tool (M16x2 threaded rod, washers, nuts, thrust bearing)
_DSC3881 by Norbert Ogiba, on Flickr
Pilot bearing was replaced with a new OEM unit
_DSC3880 by Norbert Ogiba, on Flickr
Dab of RTV at the corners of the front and rear covers seals them against the oil pain
_DSC3882 by Norbert Ogiba, on Flickr
I removed the windage tray, internal pan oil tubes, and pickup tube, and cleaned them with warm soapy water to make sure no foreign material was hiding in there. Cleaned them up and blew out with compressed air to make them like new.
_DSC3883 by Norbert Ogiba, on Flickr
Oil pan on, aligned, and torqued.
_DSC3884 by Norbert Ogiba, on Flickr
Old 06-09-2015, 12:17 PM
  #440
hokeplaya05's Avatar
love this project! liking all the pics of you going through the newest motor, i have an lq4 that i will be going through like you did, but i have a set of 243s to put on it. was going to bring the heads to a machine shop to have them gone through, but i may just try it myself now
Quick Reply: LQ4/T56 into 2001 BMW 540i
