Rat Rod: How will straight up drag style headers sound?
We are contemplating running dragster style headers (pointing straight up with no collector or mufflers) on a rat rod. Motor will likely be an LS3 GM crate motor with a hot cam swap and a Holley Hi Ram-intake (all top end).
How will the exhaust note be with no collector? Does anyone have a video example?
I was thinking about this with some old headers i had, but you still have to run
O2 sensors if your going to keep it efi I believe. I was going to use a collector but i would still look funny turned up headers sticking out of the hood with o2 sensors.
You could always delete O2 sensor input and run off of a table. Not sure how this is done with the OEM ECU but I think the reflash systems have O2 sensor delete capabilities.
will sound like a demo derby car,some like it some woulnt. o2 sensor will be the problem.i know you can delete post cats but not sure on primary. they are what the pcm uses to monitor air fuel ratio.
