LSX swap Monte Carlo w/ 4L80E Shift Linkage Question
Old 08-18-2012, 07:38 AM
SE-R Spec's Avatar
Default LSX swap Monte Carlo w/ 4L80E Shift Linkage Question
hey guys,
i have been searching quite a bit the past few days trying to find a shift linkage compatible with the 370 ci iron block I built with a 4L80E behind it.
i have found that a 4th gen F-body shifter and linkage from a 2000 camaro v6 will work and it has worked out PERFECT........... except for when i try and connect it to the shifter arm on the transmission. The nipple on the shifter arm of the 4l80 is quite small compared to the nipple on the 4l60 for the shift linkage connection.
I did the obvious thing and switched the shifter arms on the transmission. No cigar. The 4l60 arm is at a different angle and shorter than the 4l80 arm thus only shifting into approximately 3 gears.
anybody have a suggestion on what I should do? am i missing a piece to the arm to make it compatible? pics would be appreciated
derek
Old 08-18-2012, 02:03 PM
FatfreeGTO's Avatar
I'm assuming a floor mounted shifter and not column correct?
There is a company called shiftworks which is where I got the shifter for my 4l80e in my GTO. He should be able to help you out.
Look at this link, maybe you just need the linkage "fix-it" bracket...
http://shiftworks.com/4lx.htm
Old 08-19-2012, 12:40 PM
SE-R Spec's Avatar
i appreciate your response man. i came across that website right before i put this post up but i noticed the nipple on that shift arm they are selling is still the small nipple. the shift linkage needs the larger nipple like is on the 4l60e
EDIT: i guess they could switch that out if i talked to them.....
Old 08-19-2012, 06:24 PM
superbean's Avatar
get a shifter bracket meant for th350/th400.. and on the hole where a pin typically goes.. get a carb screw socket and fasten it to it..
Old 08-20-2012, 11:51 AM
SE-R Spec's Avatar
I just called shiftworks and they said they couldn't help me.
Superbean, can you give me a part number or a pic of what you are talking about? I have a bracket from the 200r still if that is the same thing you are talking about
Old 08-20-2012, 12:20 PM
sawzall wielding director
G-Body's Avatar
If you have a welder, why not just remove the larger ball from the 60e linkage arm and weld it to the 80e arm?
Old 08-21-2012, 09:21 PM
SE-R Spec's Avatar
that thought actually crossed my mind. it looked like aluminum though and i dont have a tig welder.
can anyone confirm the metal type for the shifter arm?
Old 10-10-2012, 02:49 PM
85mcss's Avatar
Ive been dealing wiht the SAME problem with the floor shifter & stock cable/linkage on my Monte... I started by grinding off the pin on the stock 80E bracket, redrilled the hole at a higher point, and then stuck my stock shift linkage pin w/ cotter key into it. It works for all gears except first.
The 80E bracket is defintiely some sort of steel and has a hard coating on it. Had to bear down on it pretty hard with two new bits to chew through the coating..
It sure looks like the 4LE-C shiftworks bracket could work but if they told you it wouldn't, I dont know what to say...
Subbed for a solution!
Old 10-12-2012, 12:24 PM
SE-R Spec's Avatar
sorry for late response.
used 99 camaro v6 shifter and cable with 4l80e shifter arm and swapped the 4l60e shifter arm nipple over to the 4l80e.
with the hedman hedders (pn 14510 i believe) i had to flip the nipple towards the trans for it to work so it would not hit the headers but it shifts into all gears
Old 10-12-2012, 05:46 PM
85mcss's Avatar
Did the fbody shifter fit under the stock console? Im trying to keep mine as stock as possible on th inside and use the stock console.
Old 12-05-2012, 05:17 PM
SE-R Spec's Avatar
i havent got the inside together yet. the shifter isnt even bolted down right now lol. i am in the midst of making the fuse block.
sorry for late response. i should be doing a build thread in a month or two
Quick Reply: LSX swap Monte Carlo w/ 4L80E Shift Linkage Question
