85 Mustang Coupe Ls1 Turbo
Old 08-18-2012, 12:58 PM
LSX FOX's Avatar
Default 85 Mustang Coupe Ls1 Turbo
its been exactly a month today since i started the project.
Stock fresh ls1 for now, t56 6-speed tranny, ls1 radiator/fans, efi, PCM inside car, 2000 camaro gauge cluster, aje tubular kmember, 76mm turbo/50mm bov/50mm wg., custom built turbo kit.
Attached Thumbnails 85 Mustang Coupe Ls1 Turbo-255296_3202369636646_231241507_n.jpg   85 Mustang Coupe Ls1 Turbo-488277_3202364796525_1725519857_n.jpg   85 Mustang Coupe Ls1 Turbo-528099_3202371796700_845596575_n.jpg   85 Mustang Coupe Ls1 Turbo-539091_3202355996305_1494965804_n.jpg   85 Mustang Coupe Ls1 Turbo-tn-3-.jpg
Old 08-18-2012, 03:53 PM
95civic2005's Avatar
How do you like the camaro cluster? Pretty easy install? Trying to decide if thats the way I wanna go or not. Good luck on the build!
Old 08-18-2012, 05:41 PM
LSX FOX's Avatar
not exactly easy, i had all the pinouts for the cluster and the pcm from alldata and you need the pinouts for the mustang blinkers, highbeams, etc. if you want all that to work on the cluster..you also gotta run the obd2 connector with the serial data wires which at the moment mine isnt even working right, well its not showing the mileage on it. everything works out pretty well though, just time consuming and some cutting behind the old cluster is involved..and yea thanks its been alot of work but i know ill be happy when its all done and itll be different. make sure you get the connector for the back of the ls1 cluster with all the wires coming out of it.
Quick Reply: 85 Mustang Coupe Ls1 Turbo
