What stall speed torque converter will gain a little FUN???
Old 08-20-2012, 02:11 PM
1970's Avatar
Default What stall speed torque converter will gain a little FUN???
Car is a stock 1970 Chevelle SS clone weighing 3600 empty
STOCK 2004 Buick Rainier all aluminum 5.3L LM4 (62K miles)
STOCK freshly rebuilt 4L60e transmission is from a 2004 van
Rear axle ratio is the stock 1970 Chevelle 2.73 open
Car will be used for long haul Power Tour travel, so mileage is important BUT want to have a little fun time to time from the traffic light...
2 Questions:
What stall speed torque converter was stock?
Old 08-20-2012, 02:25 PM
superbean's Avatar
as long as you can lock up your converter you'll be fine with any choice really.. Can't really go too big with a converter IMO. Most truck guys which have a setup like yours like a 3000-3600 stall as a 5.3 makes peak torque around 4200 rpm ish.
Old 08-20-2012, 03:24 PM
1989GTA's Avatar
"Rear axle ratio is the stock 1970 Chevelle 2.73 open"
Not sure what your tire diameter is but maybe you want to go to something like a 3:23:1 gear. Maybe more depending on your tire diameter.
Old 08-20-2012, 04:11 PM
1970's Avatar
4L60 has .7 to 1 fourth gear (Tires 225/70-14 (26 tall), 2.73 gears at 1605rpm=65mph)
4L60 has .7 to 1 fourth gear (Tires 225/70-14 (26 tall), 2.73 gears at 1730rpm=70mph)
Old 08-20-2012, 11:31 PM
1970's Avatar
think stock stall is 1600 to 2200
what stall will be fun???
your thoughts...
Old 08-21-2012, 05:30 AM
BLK02WS6's Avatar
I would run a vigilante 3600... but, I would change the gears to 3.73 as well... make sure to put a good cooler on the trans with a stall converter.
Quick Reply: What stall speed torque converter will gain a little FUN???
