Mustang Swap Radiator
Old 08-23-2012, 09:11 AM
dmracing's Avatar
Default Mustang Swap Radiator
Everyones always asking, how bout people post pics of thier set ups.
Old 08-23-2012, 11:00 AM
LILHEMI's Avatar
Old 08-23-2012, 12:34 PM
Sarg's Avatar
Is everyone pretty much doing a 29x19 double pass right? Also curious if anybody with the big stall autos is running a trans cooler in their radiator or just running a seperate cooler.
Old 08-23-2012, 12:36 PM
1bad03snake's Avatar
Old 08-23-2012, 06:44 PM
Tunink's Avatar
Running stock LS1 car radiator with fans. Keeps my 408 @ 160* constant. Mounts perfect in a fox as well.
Old 08-23-2012, 09:40 PM
dmracing's Avatar
What modifications did you have to do?
Old 08-23-2012, 09:45 PM
Builtz71's Avatar
Originally Posted by 1bad03snake
Is that ran through the radiator to,or just through the cooler?
Old 08-24-2012, 10:41 AM
Sarg's Avatar
Yeah I am debating the whole radiator+trans cooler or just running a trans cooler by itself.
Old 08-24-2012, 01:10 PM
doug118's Avatar
Pictures plus part info would be more helpful
Old 08-24-2012, 01:53 PM
Tunink's Avatar
Um nothing. I think there was some rubber gromet that I took out on the bottom support, but it slides right in and fits perfect. We used a metal plate that goes over the top of the radiator for a better seal, but the thing works perfect.
Old 08-25-2012, 09:41 AM
zipster's Avatar
Stock 99 Z28 radiator, cut the locating pin off the passenger side of the bottom tank.
Old 08-25-2012, 10:13 AM
Sarg's Avatar
Just out of curiosity, I noticed some ports while looking at the fbody radiator pictures that I am unclear about. On the drivers side lower there is a small little tube. Is that just a mount? Then on the passenger side there is a medium sized port below the radiator hose area. Is that for a sensor or something? It looks to be below the transmission cooler lines.
Old 08-25-2012, 10:40 AM
Travbabble's Avatar
It has an integrated transmission cooler in the radiator. Here's my setup so far, it's not finished obviously. I just used the camaro radiator.
Old 08-25-2012, 11:52 AM
Sarg's Avatar
The one in this picture looks like there is something that is supposed to go below the trans cooler and then something else on the bottom passenger side. It is from this ebay listing:http://www.ebay.com/itm/140769365774...84.m1423.l2649
Quick Reply: Mustang Swap Radiator
