Short crank lq4???.please verify (pics)
Old 08-26-2012, 11:20 PM
Builtz71's Avatar
Default Short crank lq4???.please verify (pics)
I hate sounding like a newb,but not real sure if this is the short crank or not..
If it is,what will I need with this flexplate to mount a th400 to it?without buying a custom converter
Crank pic
With "supposedly" ls1 flexplate,just sitting on there..not bolted up
Any info will be appreciated!
Old 08-27-2012, 03:18 AM
Adam123's Avatar
Are the heads stock and if so are they iron? IIRC the iron headed lq4 had the long crank. Mine did. I'm not sure how true my statement is, but I seem to remember that.
Old 08-27-2012, 03:19 AM
Adam123's Avatar
I think you buy a spacer and not a converter.
Old 08-27-2012, 05:05 AM
LS1MCSS's Avatar
That is the short crank motor. I don't use the GM spacer. I use the one made by Hughes and the curved flexplate.
Old 08-27-2012, 10:39 AM
Builtz71's Avatar
the flexplate i have i believe is the curved one..i was also considering buying the tci flexplate,and running a tci or hughes converter from summit..what do you guys recommend?
Old 08-27-2012, 07:17 PM
S10xGN's Avatar
I used the GM 0.400" spacer and flat 'plate.
Old 08-27-2012, 07:26 PM
Centerfold_Firehawk's Avatar
i also need infor on this subject as i just bought a iron headed 6.0 out of a 2000 2500 and want to put it in my 2002 silverado 1500 that has a 4.8. i got the flexplate with the 6.0 off the 4l80e do i need the same .400" spacer as well and if so what is the gm part number
Old 08-29-2012, 10:34 PM
Builtz71's Avatar
Talked to Chris from circle d today..he told me with the power my motor is making,and me planning on running a shot on it later..that I need a sfi certified flexplate..so I'm just gonna go with there flexplate and ls to th400 converter..
Old 08-30-2012, 12:12 AM
Bo185's Avatar
That motor will not work with the 4l60e you have. The conveter will not bolt up. As the longer crank flange will prevent it form fitting. You could just run a 4.3L converter and the flat flex plate and that should work.
Quick Reply: Short crank lq4???.please verify (pics)
