Fuel line 101 inexpensive way to plumb a conversion and not break the bank
I had searched and serched was looking at how to plumb my LS6 69 Bird conversion. Altough the kit is not cheap >$200, using OEM economical connectors and inexpensive nylon line if you will ever do another car it will be under $50 to do the next I thought this is hard to beat, anyone that has bought braided stainless and all the fiitings knows this is cheap! - I hope this helps anyone doing a conversion on a budget
https://ls1tech.com/forums/fueling-i...ttachment.html
Here is an even cheaper way - https://ls1tech.com/forums/16560263-post348.html Idea wasn't mine but I got a new computer and no longer have a link to the thread with Caddy info in it.
Those lines, a filter and a couple $2 Dorman pieces should be enough for a returnless setup.
