Ls1 Oil pan
Old 09-02-2012, 12:23 AM
project nc's Avatar
Default Ls1 Oil pan
Hello all,
I have a 2004 GTO Ls1 and I'm planning on installing it in my 72 Cutlass convertible. Can someone tell me what oil pan I can use without hitting the crossmember?
Old 09-02-2012, 12:54 AM
97camaroguy's Avatar
Hey project nc check out this guys build of a 71 cutlass. He dropped a 6 litre in his so same **** different day lol.
https://ls1tech.com/forums/conversio...l#post11712715
this is the thread but i linked you right to where they are talking about oil pans.
hope this helps
Old 09-02-2012, 09:27 AM
SUPERBOOST's Avatar
Holley pan woul'd probably be my choice of the various pans availible,if you shop around you can find it for $350-$375.You can use an fbody pan but you will probably have to do a little surgery on the pan or the crossmember.
Old 09-02-2012, 09:48 AM
Kingstir's Avatar
Default oil pan
I have a '70 El Camino with an LS2, and I am using a MAST Motorsports oil pan.
It works just fine and has plenty of clearance.
Blanchard
Attached Thumbnails Ls1 Oil pan-img_3299.jpg   Ls1 Oil pan-img_3300.jpg   Ls1 Oil pan-img_3302.jpg
Old 09-02-2012, 10:06 PM
project nc's Avatar
[QUOTE=Kingstir;16681208]I have a '70 El Camino with an LS2, and I am using a MAST Motorsports oil pan.
Damn Kingdstir... That looks reasl good snd looks to have no issues at all.Clearance all around How much did the pan go for?
hope this helps
Thank you very much. I was looking at this thread ealier in the day Very helpful
Old 09-02-2012, 10:12 PM
99VetteFRC's Avatar
I put a CTS-V LSA pan in my Chevelle. Pretty close to the same thing.
Old 09-02-2012, 10:13 PM
Glad I could help man. Good luck with the build!
Old 09-03-2012, 07:28 AM
Kingstir's Avatar
I think that my oil pan was about $430.00 when I bought it a year ago. Looking at the MAST website, they have it priced at $499 now. You might check out the Holley oil pan as well.
Blanchard
Old 09-03-2012, 10:01 AM
oldgoat69's Avatar
Take a look at the Canton pan and filter mount.
Quick Reply: Ls1 Oil pan
