any other REAL Cadillacs out there with a ls swap?
Old 03-02-2014, 05:03 PM
  #41
59 camaro's Avatar
sick ride, one day ill be doing a swap on a 59 cadillac coupe d ville
Old 03-08-2014, 01:14 PM
  #42
sprech's Avatar
duplicate
Old 03-08-2014, 01:15 PM
  #43
sprech's Avatar
Picked up a 1961 Series 62 Coupe. Has been sitting for about five years. Last time it ran, it blew smoke pretty bad. I'm going to try and start it up tomorrow. L96 with 6L90E w/2k on it is on the way. May be a while until I actually get to the swap with everything that is going on.
'61 Cadillac Series 62
For the helluvit, I dumped a little gas in the carb, turned it over and it fired.
Old 03-09-2014, 08:27 PM
  #44
Ls1.63cad's Avatar
Got the disc brakes done just need to finish plumbing master cylinder
Attached Thumbnails any other REAL Cadillacs out there with a ls swap?-image-3893498030.jpg   any other REAL Cadillacs out there with a ls swap?-image-480725010.jpg   any other REAL Cadillacs out there with a ls swap?-image-3506982332.jpg
Old 03-10-2014, 12:10 AM
  #45
sprech's Avatar
What set up did you use to convert to disc?
Do you have any advice on this swap? Things you ran up against or that you would have done differently?
Old 03-15-2014, 11:44 PM
  #46
Ls1.63cad's Avatar
I used the classic performance products kit it will let me keep the stock wheels so I can run the white walls and caps. The space for the exhaust header on driver side is super tight with the steering box and took some work to build a header and the engine mounts hade to be built other then that It was all the same swap stuff with most cars
Old 03-15-2014, 11:49 PM
  #47
Ls1.63cad's Avatar
The wheel and tire
Attached Thumbnails any other REAL Cadillacs out there with a ls swap?-image-3869948586.jpg
Old 03-16-2014, 12:06 AM
  #48
sprech's Avatar
Nice! I am really leaning towards a good set of white walls on steel wheels or maybe something aftermarket, not sure if white walls would go with a set of torq-thrusts or not, but I'm keeping my options open. Not really a fan of the 20's it currently has.
Old 03-17-2014, 11:57 AM
  #49
Ls1.63cad's Avatar
The trans tunnel did get cut for the 400 and shifter the battery moved to drivers side odyssey dry cell I built the exhaust to be off ground when car is laid out a lil work getting it out and around X frame a lot of mandrel bends made it nice and tight
Attached Thumbnails any other REAL Cadillacs out there with a ls swap?-image-2384211423.jpg   any other REAL Cadillacs out there with a ls swap?-image-4074781271.jpg   any other REAL Cadillacs out there with a ls swap?-image-3675279794.jpg
Old 03-17-2014, 02:12 PM
  #50
sprech's Avatar
You said the muscle car pan, which I believe is the LH8 sits about 3/4" above the crossmember, correct? I think I'll take the LH8 I got from BRP and use it on the Cadillac instead of the Bird, and get an autokraft pan for it instead.
Old 03-17-2014, 02:14 PM
  #51
sprech's Avatar
The wheel and tire
I do love these hubcaps, I wonder if anyone is making an aluminum wheel with this design. I figure it would be pretty pricey to have one offs made.
Old 03-17-2014, 08:54 PM
  #52
Ls1.63cad's Avatar
Colorado customs made some for this 60 I called they said would be 1700 a wheel. The caps I'm running are 62 caps 61 look the same but have the big crest
Attached Thumbnails any other REAL Cadillacs out there with a ls swap?-image-1063714806.jpg
Old 03-17-2014, 10:37 PM
  #53
sprech's Avatar
Holy moly, that's a lot of $$$
Old 03-18-2014, 02:57 AM
  #54
Sub-par's Avatar
I want to do a 77 or so square headlight D-body coupe with a twin turbo 6.0... On Daytons. Wide Daytons, I'm talking a 17x11 with a 335 series tire.
Great builds guys. Once my money tree grows up...
Old 03-22-2014, 11:46 AM
  #55
TEDSgrad's Avatar
If anyone's interested....My elderly father is not going to finish his '65 Eldorado convertible build - 2,150 produced. All original except block (threw a rod). My father is the second owner and has owned it since '75.
http://1drv.ms/1jmcNF3
$5k takes it.
Old 03-24-2014, 12:23 PM
  #56
Jason454's Avatar
Awesome car. But what does a fake Cadillac look like?
Old 03-24-2014, 04:02 PM
  #57
sprech's Avatar
Among other things, I believe they were called Catera's and Cimmaron's.
Old 03-26-2014, 07:58 PM
  #58
Ls1.63cad's Avatar
Real as in all Cadillac parts as in the engine trans rear end are all cadillac and don't share with any other car
Old 03-27-2014, 12:55 PM
  #59
autocomman's Avatar
Wrong wheel drive caddys
Old 03-27-2014, 02:22 PM
  #60
59belair's Avatar
Some wrong wheel drive Caddys were good for something. heart donors for example. but you do have to correct a few things that Cad had all screwed up and bass ackwards first
I do love those older Caddys also. ya gotta love anything with fins. nice work LS1.63Cad :thumbs:
Quick Reply: any other REAL Cadillacs out there with a ls swap?
