Lq4 with ls1 accessories,please help!
Old 09-07-2012, 08:34 PM
Builtz71's Avatar
Default Lq4 with ls1 accessories,please help!
I've got a lq4 block,with 04 Gto ls1 crank pulley,alternator and bracket..just bought a ls1 water pump off a member on here..when I bolt it up,the water pump pulley and tensioner sets back further then the rest of the pulleys..do I have to buy that water pump spacer kit?..because I thought the spacers kit was to run a ls1 water pump,with truck accessories?..I'm pretty confused.some please help me out on this!
Old 09-07-2012, 10:15 PM
Builtz71's Avatar
Come on guys,no help?!
Old 09-08-2012, 02:13 AM
garys 68's Avatar
Any chance you bought a corvette water pump? It sets back farther than the gto/f body.
Old 09-08-2012, 03:27 AM
sierrac3_s2000's Avatar
Yep sounds like you have a Vette water pump and tensioner. I think the pump will be fine, you can pull the pulley out a little if you have to and you can get a f-body tensioner so it lines up.
Old 09-08-2012, 10:43 AM
Builtz71's Avatar
Damn it, I think it was off a vette!..those spacers are like $80,do you think that would get the pump and tensioner out far enough?..I just don't want to mess the pump up,trying to get the pulley pulled forward.
Old 09-08-2012, 11:11 AM
Rick Speed's Avatar
Get the fbody tensioner and you should be good. At most might need to add washers to tensioner.
Old 09-08-2012, 11:53 AM
garys 68's Avatar
The spacers are $80, extra gasketrs $10. You can get a new F body pump off ebay for $100.
Quick Reply: Lq4 with ls1 accessories,please help!
