Need Spark Plug Wires for 69 Camaro w/ LS2 & Stainless Works Headers
As mentioned I have an LS2 with Stainless Work headers. I have a set of MSD 32823 spark plug wires, but with the #5 wire installed about an inch of the boot is pressed up hard against the header.
I happened to have the stock 2008 TBSS plug wires and they will work if I trim some of the excess material from the #5 boot, but of course as luck would have it a couple of the wires are bad.
I know I could mix and match a set to fire up the motor, but I would rather buy the correct ones and be done with it. Any recommendations?
wires
I just got some Jegs brand wires. Made is USA with multi angle boots. http://www.jegs.com/i/JEGS-Performan...d=#moreDetails
