Which ly6 accessories with vvt delete?
Old 10-20-2012, 09:08 PM
Powe's Avatar
Default Which ly6 accessories with vvt delete?
Doing some research on my 67 nova with tci front clip using ly6 block and ls3 intake. I read that the Ctsv front drive accessories wouldn't work on my iron ly6 block and that I needed to use the corvette http://paceperformance.com/i-6255430...-engines.html?
I talked to vintage air and they said they sell a low mount bracket and ac compressor for their system too.
Any clue on this?
Old 10-21-2012, 12:29 AM
Bo185's Avatar
If you delete the VVT and run a LS2/3 timing cover it will fit the vette drive. The VVT cover sticks out and hits most water pumps other that the VVT ones.
Old 10-21-2012, 06:45 AM
Rocketrod's Avatar
Any clue on this?
The VA low mount bracket still requires you to notch your subframe to fit.
Old 10-21-2012, 10:05 AM
Powe's Avatar
I'm buying the VVT delete kit for the car which comes with the front timing cover. Simply trying to figure out which complete front drive accessory package from GMPP I can use on the LY6 iron block (CTSV, or Vette)? Both are about $730 for the complete set up. I was told there are no holes and possibly no bosses to drill for some brackets on the CTSV unit?
Is this for a 66-67 Nova using TCI Mii front clip? Do you have pics of how this looks?
Quick Reply: Which ly6 accessories with vvt delete?
