Now thay I think I have top dead center
What this doesn't say is which one is intake and exhaust :crazy: I'm thinking on #1, the 2nd # 1 (driver side) is exhaust?
AllData shows 22 ft lbs.
Turn the number one piston to top dead center of the compression stroke. In this position both of the cylinder number 1 rocker arms will be off lobe lift.
Tighten exhaust rockers on cylinders 1,2,7 and 8
Tighten intake rockers on cylinders 1,3,4, and 5
Rotate crankshaft 360 degrees
Tighten exhaust rockers on cylinders 3,4,5 and 6
Tighten intake rockers on cylinders 2,6,7 and 8
