Computer issues
Old 10-28-2012, 10:32 AM
tshirtguyjim's Avatar
Default Computer issues
Any suggestions on where to mount the computer on a 1967 RS Camaro? I'm installing a LS2 out of a 2006 GTO, and want to use the factory wiring harness.
Old 10-28-2012, 05:17 PM
LS1Tech Sponsor
psiconversion's Avatar
In the glove box, above the glove box?
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old 10-28-2012, 08:04 PM
bczee's Avatar
Under the dash, just behind the ash tray. That way you don't lose the glove box usage.
Old 10-28-2012, 10:55 PM
Thanks for the advise. Where do you suggest I penetrate the fire wall?
Old 10-31-2012, 07:48 AM
LS1Tech Sponsor
We use a grommet seal on our harnesses.
Jon
PSI
__________________
Ebay Store
Old 10-31-2012, 04:35 PM
Rocketrod's Avatar
If you are going to install a Vintage Air a/c I would highly suggest you install the evaporator now and then decide if you can fit your ecm under the dash. I have the smaller E38 ecm and the glove box was the only place that you could reasonably fit the ecm, so I mounted mine under the hood on the radiator support, https://ls1tech.com/forums/16355047-post160.html
Quick Reply: Computer issues
