1970 Nova LY6 TT build
#61
Thank u , I know that it's worth the headache & I want air & hear & defroster 4 once & it's gonna work but now I'm planning & analyzing what will work & what won't work & what else that got 2 go in. Thank u again.
#62
wastegates ??
What brand do u all prefer ?? Tial , Turbo smart , Precision. I'm looking 2 get 2 44 OR 45 MM wastegates w/ V band. I'm not worried about the cost , just want a good wastegate 4 my twin S366 turbos. Any ideas ?
#63
Also for your low mount AC compressor is that the alan grove bracket with the Sanden 709? I'm looking into that same set up which means i have some notching to do
#64
Sorry I'm not an experienced turbo guy, but i have always heard good things about the Turbonetics RG-45. Are you going to keep the stock valvetrain? Or change it to the LS9 spring set up?
As for the cross member , all it was is trimming excess metal that u don't need & it looks way better.
#66
Thank u , the 3.5 hot pipes will be fine , the 2.5 flange off the turbo will go 2 the front of the radiator then y 2 gether into single 3.5" or 4" pipe 2 the TB. If I can sell this intake , TB , Elbow & sensors , I want 2 get the Holley Hi Ram , so I can buy the intercooler from 417 Motorsport 2 go between the top lid & bottom intake so I can have my radiator 2 get full air flow & my AC condenser & trans cooler can be more separated for cooling issues. I don't want the radiator , intercooler (a2a), ac condenser & Trans cooler stacked , cause I don't want any overheating issues & plans 2 do what Shawn (Crusty Nova) did. Also , I'm cutting alot of the sheet metal off on the core support & gonna fabricate a shroud around the radiator to the core support so it looks better & direct the incoming air thru the radiator , not around it.
#68
I agree about the packaging of the intercooler. Once that intake set up I have sells , then here comes Holley Hi Ram. The a2a Treads tone is around $500 , but the a2w from 417 Motorsport is around $1000-1200 , I can't remember , but when u add elbows & hoses to the cold side of a2a , the price will go up around $100-200 depends on what u buy. I'll keep u guys updated , but going out of town in a couple of weeks. Happy Labor Day everyone.
#70
#72
Thank u William , that was one of them , that I was also looking @. It sometimes a little frustrating 2 choose between 3 or 4 good wastegates company.
#74
Thank u , I'm thinking of low mounting the turbos down between the frame rails & engine-tranny location so the exhaust manifold goes in stock location & have short pipe to the t4 flange & make a support off the frame rails , but that short pipe will have a flex joint ???? I know that I'll have 2 buy the pump for the oil drain but @ least I could put the coils back on the valve cover.
#75
pics
Here an idea , it's not up high enough , I just put the turbo on a seat pad & rolled it under for an idea & get block huggers or CTS- V exhaust manifold might work. What do u all think , I sort of like it but gotta get everything in place to see if it will work.
#76
Wastegates:
http://www.jgstools.com/turbo/wgpg.html
Top notch made in the USA stuff.
forcedinductions.com are a good vendor
check out v-bands, couplings, vacuum hose and w2a intercoolers at frozenboost.com
good luck!
good luck!
#77
Wastegates:
good luck!
good luck!
Again thank u.
#78
Sold my Edelbrock intake & Wilson set up. Will be going home today & will stop by Summit Racing in Akron 2 Pick Up My Holley High Ram intake & 92 mm TB.
#79
Can't wait to see it on there! Have you ordered the a2w intercooler for it?
I don't know how you will find space to mount and plumb everything down low, but it will be uniquely awesome if you can make it work. I think in that position you may want to just hang it off the manifold or support by the block somehow. Something like this: http://www.airpowersystems.com/corve.../z06_eng_l.jpg
#80
