Turbo 5.3L 1968 Camaro Build, TH400, S480
Old 02-08-2013, 06:16 PM
STEVE PWC's Avatar
Looks great. Keep the pics coming
Old 02-08-2013, 09:50 PM
LS1NOVA's Avatar
Looks good. Those S400s are big suckers.
Old 02-09-2013, 05:17 AM
Sarg's Avatar
I have pretty much had to design my cooling system around my S400 in my build, lol. Everything gets moved for the turbo! Are you doing a full 5" exhaust on it or splitting it for duals?
Old 02-09-2013, 09:48 AM
scottr126's Avatar
I am planning on doing full 5" and then dumping it before the axle. If its too loud I will look into doing a dual setup after that.
Old 09-28-2013, 05:48 PM
scottr126's Avatar
Its been a busy summer, I haven't had any time to touch the car but over the past week or so I have been able to start final assembly. I updated the 1st post!
Old 11-10-2013, 06:57 PM
scottr126's Avatar
It runs and drives!!
I also started putting the interior back together.
Pics added to the first post!
Old 11-29-2013, 07:27 PM
scottr126's Avatar
Almost forgot to mention, I do Powder Coating and Sandblasting. If anyone needs anything done contact me!
I just did these valve covers for my Camaro!
Old 11-30-2013, 07:30 AM
schreurs1's Avatar
Man the shop your working in looks like a Garage-Mahal. GT-R and an R8 in the backround!?
Nice clean build
Old 03-19-2014, 11:30 AM
projectFword69's Avatar
Just curious what you used on the hot side black that will hold up to the heat?
Old 03-25-2014, 10:45 PM
CarrBoost83's Avatar
new to these builds and doing one as we speak, curious as to where you installed your o2 sensors,AFR sensor? Also who built your turbo heat blanket?
Old 08-06-2014, 09:04 PM
scottr126's Avatar
The factory o2 sensors just go in the pipes after the manifolds before the turbo. The wideband is in the downpipe, about 30" from the turbo.
The turbo blanket I found online, I don't remember where.
Old 08-06-2014, 09:06 PM
  #32
scottr126's Avatar
Well I finally got a real tune in it. On our shop dynojet it made 635 whp @ 12 psi on 93 octane, and it made 843 whp @ 20 psi on 110 octane, it was spinning pretty bad. This thing rips on 110.
Old 08-08-2014, 10:39 PM
  #33
nasty64's Avatar
Well done!!!
Old 08-22-2014, 12:09 AM
  #34
game-over's Avatar
If you would be willing to talk to me. I would appreciate it.
I am most likely ditching the ls1 spray this winter. I want my car to end up similar to yours.
Old 08-22-2014, 11:58 AM
  #35
RonSSNova's Avatar
Very nice job. And awesome numbers!
Do you plan to take it to the drags?
Ron
Old 08-23-2014, 07:19 AM
  #36
wolfinsheepsclothing's Avatar
Clean setup. The BW compressor covers are HUGE!
Old 10-19-2014, 10:09 PM
  #37
scottr126's Avatar
I took it to the track for the first time ever a couple weeks ago. It ran consistently 9.6-9.7 @ 142. Not too bad for the first time out. The converter was way too tight and I broke one of the stock rear axles with the trans brake. It was coming out of the hole very slow and I had a weird stumble the top of 1st gear. A week later equipped with new Factory 10 axles I went again but still couldn't get it to come out hard so I didn't go any faster and it still had a stumble in 1st.
So I pulled the converter and sent it out to be loosened up. I also ordered a Glenn's Performance sleeper gas tank and some CalTracs. All of which I installed yesterday. Hopefully next time at the track I will go a bit faster!
Ron
Old 10-19-2014, 11:05 PM
  #38
garrysturbo's Avatar
Nice Dyno # & great 1st track outing. This is a really clean set up & will be cheering u on 4 the lower ET. How is ur Unisteer rack kit. , I have the manual one but u got the power assist ?? I like how it set up but I'm thinking of going power steering. Good luck & u'll get the ET ur looking 4.
Old 10-20-2014, 07:43 PM
  #39
nasty64's Avatar
Well done!!!!!
Old 10-20-2014, 08:20 PM
  #40
scottr126's Avatar
The Unisteer power rack kit is awesome. Fits great and works great! I can tell you however that eBay tubular control arms will interfere with it and the control arms need some "clearancing". I am going to put my stock arms back on soon.
Quick Reply: Turbo 5.3L 1968 Camaro Build, TH400, S480
