Turbo 5.3L 1968 Camaro Build, TH400, S480
Old 12-03-2012, 09:15 PM
scottr126's Avatar
Default Turbo 5.3L 1968 Camaro Build, TH400, S480
I am putting a turbo 5.3L truck motor in my 68 Camaro. Here is the setup:
-LS1 F-body accessories
-LS1 intake manifold
-Unisteer rack & pinion kit
-Hummer H3 oil pan (http://www.ebay.com/itm/300705032654)
-Modified Small block frame mounts
-Energy poly mounts
-Turbo 400 transmission
-Ebay adapter brackets
-BW S480 turbo
-Sumped stock tank
-Holley Billet fuel pump
-Autometer gauges
-Fuelab FPR
-1000cc injectors
-Current Performance wiring harness
-Speed Inc. turbo cam
-Driveshaft Shop aluminum driveshaft
The car had a 396 big block in it that made a whopping 200whp on a Mustang dyno. This was not acceptable.
To make this easier to read I will add more pictures to the 1st post as I move along on this project.
UPDATE 12-20-12, Turbo Placement:
Update 1-15-13: Turbo kit has been further built. Its coming together!
Update 11-10-13: IT RUNS!!! Also started putting together the interior.
Old 12-04-2012, 11:31 AM
WR450SM's Avatar
The alternator will be very close. Some have had to slightly grind the alternator for clearance, others have fit without mods. It really depends on the height of the motor mounts / plates used.
Old 12-19-2012, 01:23 PM
Boosted68's Avatar
Man our cars look identicle! I even pulled out my 454 and am doing a turbo 5.3 as we speak! I'm not using the same accessories as you so I'm not much help I just wanted to say our cars have twins lol. Nice ride!
Old 12-19-2012, 01:51 PM
scottr126's Avatar
Got the motor in!
Old 12-19-2012, 03:10 PM
WR450SM's Avatar
Looking good so far. What are your plans for the turbo(s), manifolds, piping layout etc?
Old 12-19-2012, 09:25 PM
LS1 pwrd NOVA's Avatar
Pic of the oil pan on how much it hangs below the Xmember please?
How far is your passenger head from the firewall?
Got pics of your modified small block mounts?
Old 12-20-2012, 08:38 PM
scottr126's Avatar
Running a Borg Warner S480 turbo and flipped truck manifolds. I put up some pictures of the turbo mounted in its final spot. Its a tight fit but will work great.
The oil pan hangs a solid 1.5-2" below the crossmember. Its definately not ideal but will work for now.
The passenger head is about 1" away from the firewall.
I dont have pics of the mounts. Basically we welded in tubes 3/4" above the oem holes in the mounts to basically raise the motor 3/4".
Old 12-21-2012, 05:59 AM
Sarg's Avatar
Running a similar turbo and engine in my little mustang. I did the 92mm turbine and 1.19 ar t6 housing. Which did you go with?
Old 12-22-2012, 06:09 AM
bmf5150's Avatar
Looking good
Old 12-28-2012, 09:56 PM
scottr126's Avatar
Updates at the top.
Old 12-28-2012, 10:15 PM
mod
mod's Avatar
here is a pic of my 67 camaro with a 5.3 with turbo
Old 12-29-2012, 11:13 AM
scottr126's Avatar
Yah I saw that, it looks great. Do you have any pics of the passenger side header/manifold and the turbo support bracket? I need some ideas.
Old 12-29-2012, 04:41 PM
mod
mod's Avatar
passenger side exhaust is a custom made log manifold with turbo flange made on it
drivers side is a 99 camaro manifold with a pipe from it to the back side of passenger manifold
you can buy the one on passenger side from Yates EFI check out their web site YATESEFI.COM talk to Randy very helpful and all round nice guy
MARK
Old 01-15-2013, 09:51 PM
scottr126's Avatar
Updated at the top. More turbo kit progress!
Old 01-15-2013, 10:46 PM
SUPERBOOST's Avatar
Looks good ,thats going to be a nice looking turbo kit.
Old 01-15-2013, 11:30 PM
Rickys S/C Z28's Avatar
man i love this ! one day my 67 will get a ls and turbo
Old 01-15-2013, 11:55 PM
pairof69s's Avatar
what flexplate/converter setup are ya using..? this is gonna be a fun street car..! doin a carbed Lq9 in my 69...eventually will be force fed
Old 01-20-2013, 04:09 PM
scottr126's Avatar
I am using a converter built for a Th400, I cant remember the brand off the top of my head, its a smaller company. The flexplate is by B&M. And I had to use a crank spacer to fill the gap between the converter and crank.
Old 02-07-2013, 01:49 PM
GIMPY02's Avatar
its a Neal Chance bolt together casper... This is not an AWD vehicle, you gunna be able to handle the power of a ls motor sissy
Old 02-08-2013, 07:57 AM
Mystic97's Avatar
I'm glad ya took this route over modding that 396 BBC boat motor.
his is going to be a whole new game for you compared to AWD 800 HP laggy, no torque 4 bangers.
Quick Reply: Turbo 5.3L 1968 Camaro Build, TH400, S480
