Fuel pressure issue..
I have noticed that my car does run well under part throttle and full throttle typically. However under hard loads like a long steep hill, or when I mat the gas it will feel really weak and then pick up on the top end.
I ran my scanner on the car, and it will have normal timing curves under light throttle (40deg to 30 deg variable) but when I stand on the gas, it drops to 8-10 deg and the engine feels confused and doesn't pull whatsoever.. pulling ignition timing due to knock im assuming
I put a fuel pressure guage on the car (B&M brand, not some ebay junk) and it is idling at 47-48 psi. When I rev it, it goes up to about 50 then dips to about 40 psi. when I hold throttle at around 3000 rpm, it stays around 45 psi.
Think its time for a new pump? Currently it has a Buick GN oem replacement pump which I think is supposed to run at 43 psi rail pressure, but it always seemed to run fine.
After my tune, there was a good bit of timing changes.. so I guess now its really showing how lean the motor is going and pulling timing.
All fuel lines were custom bent for this application and are new - gas tank is new, sending unit is new. The car does not sit at all I drive it about every day so there isn't any rust or debris in the line - also verified by pulling fuel filter, blew it with an air hose and no debris at all.
I need a new pump I think.. Walbro 255?
So, there is nothing you suspect to be restricting the fuel pressure.. so.. if your at 47-48PSI (which is at the LT1 pressure range). You should get a properly spec'd pump .. yeah.. the Walbro 255's are the most common choice. I use them myself.
Becareful until you change it.. you don't want to run it Lean..
good luck
BC
good luck
BC
