Gen III/IV block with a 1993-1997 T-56???
Old 01-14-2013, 03:06 PM
AlterEgo's Avatar
Default Gen III/IV block with a 1993-1997 T-56???
I have a 4.8 truck motor from a 2005 Tahoe. I found a deal for a T-56 out of both a 1993 & 1995 camaro. Both have LT1/GenII motors...
Can I use a T-56 with my 4.8/GenIII/IV block in my 70 Chevelle??
Old 01-14-2013, 03:11 PM
Verz's Avatar
Wont just swap over but read this for more info
http://www.gmhightechperformance.com...n/viewall.html
Old 01-14-2013, 03:17 PM
AlterEgo's Avatar
Every A-body swap guide set up here: LSx into 64-72 GM A-body, used a T-56 from a 1998 and up vehicle..
I know that the 1997 & below T-56 has the external slave cylinder and the 1998 & up has the internal slave cylinder. The 1998 & up are supposed to work better with this gen III motor because of the correct bolt pattern and input shaft....
Does anyone know if I can make the older t-56 work? I dont want to buy it if its not worth it....
Old 01-14-2013, 03:32 PM
AlterEgo's Avatar
Thanks for the article bro.... that kit is $398..... Might as well wait and get a LS1 t56.....
I thought I was getting a deal... Knowledge is power.. Thanks bro!
Old 01-14-2013, 04:15 PM
AlterEgo's Avatar
What about the bellhousing and flexplate and clutch? The one I was gonna use is off a LT1 because it has very low miles.... Will these even work if I do that other $398 conversion with the cover and shaft????
Quick Reply: Gen III/IV block with a 1993-1997 T-56???
