Lokar Throttle cable end and Nick Williams TB
Old 01-18-2013, 11:05 AM
dirtymoe77's Avatar
Default Lokar Throttle cable end and Nick Williams TB
Hey there, I have searched and searched and haven't found a solution to my problem. I then emailed lokar for a solution and they want very precise caliper measurements and I don't have the tools to do that.
Here is my issue. I have the Lokar LS throttle cable and the Nick Williams TB. The cable end does not seat properly in the hole in the throttle body accelerator bracket. I emailed Nick Williams two different times for a suggestion and haven't heard a word.
I've attached a pic so you can see what I'm talking about...
Anyone use this setup? Anyone found a solution?
Attached Thumbnails Lokar Throttle cable end and Nick Williams TB-photo-2.jpg
Old 01-18-2013, 11:17 AM
I need a gauge for that
Atomic's Avatar
I have the same combination
Never had a problem from mine...
Old 01-18-2013, 01:07 PM
E30-LS1's Avatar
File or machine the flats off of the Lokar cable fitting so it will seat in the hole in the throttle plate. As long as the Lokar cable is properly anchored in the fitting, the fitting can't get out of the throttle plate.
Old 01-18-2013, 02:43 PM
dirtymoe77's Avatar
Interesting....will have to see if there might be something different about that bottom hole????
Old 01-18-2013, 03:03 PM
97FormulaWS-6's Avatar
Location: Land of the Mormon's although I'm not one of them
Nothing different about the bottom hole, the difference is in the thickness of the throttle bracket, the NWTB has a thicker bracket.
Only fix is to have a custom brass piece machined up that's longer.
Old 03-06-2013, 03:48 PM
Taubr Unit's Avatar
Bump, I'm looking to buy same combo but now I see this so ill wait. Anything you guys did to make it fit better?
Old 03-06-2013, 06:00 PM
Atomic's Avatar
Like I said, never had a problem with it how it is.
Old 12-21-2014, 10:38 PM
laurentj23's Avatar
Do i need to get the mounting bracket from lokar with this setup? 100 plus total seems ridiculous for a tb cable dont you think?
Old 12-21-2014, 10:50 PM
Taubr Unit's Avatar
I ended up making my own cable stop on a lathe we have at work. Goes through both sides of the tb and centers the cable, works perfect!
Old 12-21-2014, 11:15 PM
ckpitt55's Avatar
I had the same problem with my Fast 102 tb and did the same thing as above
Old 12-22-2014, 06:31 PM
1970camaroRS's Avatar
This will work just fine as is.
Old 12-22-2014, 07:05 PM
Taubr Unit's Avatar
It will deff work just fine, I just didn't care for it so my ocd made me make a new one that fits better, lol.
Old 12-22-2014, 07:13 PM
ls1nova71's Avatar
Nice job on it too. It's little details like this that separate the nice builds from the really nice builds.
Old 12-22-2014, 10:05 PM
Taubr Unit's Avatar
Thanks a lot! Sometimes I hate myself for doing stuff like that but in the end it pays off.
Old 05-16-2017, 01:37 AM
Nativefx's Avatar
Does anyone know if a bigger fitting is now available to work with the thicker TB blade? I'd really rather not have to find someone willing to make me a small, single fitting like the one above as I'm sure it's not really worth their time.
Quick Reply: Lokar Throttle cable end and Nick Williams TB
