Finally 12mm to 3/8" NPT water temp adapter.
Just had share my purchase out ebay. Somebody finally thought about making and adapter for the guys that have the 3/8 water temp. sensor. Hope this helps.
EBAY LINK
EBAY LINK
Looks like a pretty good solution, but I have a feeling it will give an inaccurate reading. I'm currently working on a set of gm 3/8 npt temp sensors that I am turning down and threading for the LSx 12x1.5mm. Ill make a thread when they are done.
That's quite a ways out of the main stream but other than being slow to respond it should work fine when everything heats up around it and transfers the heat in.
If you throw a belt it will take so long for that thing to respond you might as well go without it.
Drill and tap the block heater plug. You can get 1/2 NPT that way
