ls2 swap in 96 z28
Old 02-09-2013, 07:37 PM
monster23's Avatar
Default ls2 swap in 96 z28
Donor car will be an 05 gto. Just wondering what I need to do. Ive read that I just need to swap the engine/tranny support and wiring harness.
Old 02-09-2013, 08:12 PM
LS1Tech Sponsor
BP Automotive's Avatar
The trans mounting isnt straight bolt up. From my understanding there is a little bit of work that has to be done.
As for the k member, just try and get the brakes and k member assembly from a ls1 vehicle if you havent already upgraded the front brakes to the ls1 brakes.
As for the harness, I can help with repinning or if you want a new factory plug and play setup with a new fbody specific firewall grommet I can do that too.
Hope I answered most of your questions.
I would upgrade to a walbro pump if you havent done so already.
__________________
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
Quick Reply: ls2 swap in 96 z28
