OK, new here, have 2 oddball questions
Hi all,
I'm well into the planning stages of my next build. It's a "47 Chevy C.O.E.
I plan on running a mid mounted LSX (probably a 5.3). Because the front portion of the engine will rest under the seat area of the cab, I will need to use the LS1 style intake.
So here's the questions; 1. Can I still use a DBW throttle body on this style of intake? 2. Is it possible to mount the intake backwards, putting the TB on the transmission side? I know it sounds odd but it would allow me to locate the engine about 4 inches forward.
Thanks in advance,
Fast
Thanks in advance,
Fast
I'm using a BBK SSI Intake on my 5.3 now. Still using the Stock truck throttle body, but the water pump will have to be changed to either a 2010+ camaro pump or modified for a front output otherwise the top neck interferes with the Throttle body.
I have seen a few builds where the manifold was flipped 180 degrees for your exact solution. In that case the water pump will not be an issue. The only thing they had to do way swap the front and rear coolant lines and block off the oil pressure switch port and relocate it elsewhere. I can check the fit on my BBK reversed when I get home if you would like and snap some photos.
Good news
OK great, that will solve some other minor issues also. jsemp1, some photos of your intake setting on backwards would great. I looked over your build thread, good work. I have built a few old trucks ('46, '54, '59 and now the '47). Will add some picks to my profile.
Fast
Fast
Here's a few of the angles I figured you would be interested in. If you want any more let me know. The cam sensor clears just fine, but the stock oil pressure one does not. It looked like I could easily thread my analouge equus gauge into the port though. Also incase you were curious the valve covers are also able to be flipped so you don't have to do any weird hose routing for the PCV.
