5.3 Swap in 71 Blazer starts and dies
Old 02-22-2013, 05:14 PM
chuckmc8's Avatar
Default 5.3 Swap in 71 Blazer starts and dies
I am installing my first LS conversion- its a 2003 5.3 and auto into a 71 2wd Blazer. I bought the eng/tranny combo with conversion harness (modified stock) and the computer programed.
When I turn the key, it starts right up and immediately dies. I bought a fuel pressure gauge, reads 55 psi with key on- could it be the vats still enabled? Thanks for any help.
The pic had a bag over the air filter during bodywork-I removed it before trying to start the engine!
Attached Thumbnails 5.3 Swap in 71 Blazer starts and dies-tn-5.jpg   5.3 Swap in 71 Blazer starts and dies-tn-6.jpeg
Old 02-22-2013, 05:28 PM
95wannabe's Avatar
Do you mean it dies when you release the key from "start" position?
Old 02-22-2013, 05:31 PM
chuckmc8's Avatar
Well, I hadn't thought about that. It only runs for a second and thats about how long it takes to release the key...
Old 02-22-2013, 05:34 PM
i r teh noobz's Avatar
VATS will cut injector pulse after about 2 seconds. See if you lose injector pulse when it stalls.
Even with VATS kicking in, it should still run if you feed it some brake cleaner or something.
Old 02-22-2013, 05:43 PM
chuckmc8's Avatar
it has an odd wire that I didnt quite understand- it is a small purple labeled "12V in start only" on the tag. I just put it with the starter wire. Anyone know if this is correct?
Old 02-22-2013, 05:45 PM
sweetk30's Avatar
ao check the hot wires.
seen a guy waist 6-7 hr's 1 day tracing down a crank / fire but soon as key back to run from crank die problem.
found it out to be he had 1 hot wire in wrong place and it was on crank hot when it needed key hot & crank hot .
soon as he swaped it over it fired and run great.
Old 02-22-2013, 05:50 PM
95wannabe's Avatar
Yea thats what I am getting at.
I can't tell you the details or where to look, but I'm guessing you have 12v in "start" key position, but something doesn't have it in the "run" position.
I'm sure someone can chime in and tell you exactly where/what to look for.
Old 02-22-2013, 06:06 PM
Follow that purple wire back to the PCM. What pin is it?
Old 02-22-2013, 06:43 PM
chuckmc8's Avatar
project for the morning. Ill post the result
Old 02-23-2013, 08:50 AM
ls1nova71's Avatar
The small purple wire sounds like it might be for a starter relay. Do you have a starter relay wired into the neutral safety switch on the trans, or are you just using the original purple wire from the ignition switch? Also, what wire are you using to power up the harness? Should be the wire that originally went to the distributor. I have seen way too many people who like to get power by plugging it into the fuse box since these trucks have places to plug things in... but it doesn't work with them.
Old 02-23-2013, 05:52 PM
chuckmc8's Avatar
For the starter, I am using the purple wire from the 71 harness and tied it to the 5.3 harness. I just added the small purple wire with those and it works ok.
For ignition, I am doing as you suggested-the ignition circuit of the 5.3 is powered by the wire that formerly powered the coil on the 350.
I double checked everything and couldn't find a problem, so I called the person that programed the computer an explained the situation. I am loading the Blazer on the trailer next week and trucking it over to his shop. He said that it sounds like the VATS is the problem. Hopefully, he will know how to get it going. I appreciate the advice you guys offered. I'll post the results next week after the computer check.
Old 02-23-2013, 05:57 PM
sweetk30's Avatar
older point type igntions has a inline resistor for the coil side.
if you dont remove it you wont get full 12 volts.
otherwise good luck .
Old 02-23-2013, 06:45 PM
chuckmc8's Avatar
[QUOTE=sweetk30;17174469]older point type igntions has a inline resistor for the coil side.
Its long gone
Old 02-26-2013, 09:30 AM
chuckmc8's Avatar
UPDATE: Turns out the VATS were still enabled. A few minutes on the laptop at the tuners and it runs good now. Thanks for the help
Old 02-26-2013, 10:11 AM
ls1nova71's Avatar
Glad irt was something simple and you got it running. Sometimes it's the little things that get you.
Old 02-26-2013, 10:28 AM
1970 ls_c10's Avatar
hey just wanted to let you know there is a site called 67-72chevytrucks.com that has a LSx swap section, very helpful for stuff like this just an FYI
Quick Reply: 5.3 Swap in 71 Blazer starts and dies
