PNP NSBU Switch 4L80E
Please help me understand this wiring diagram.
I THINK I understand that when in park and neutral you would have continuity between the OG/BK and the BK/WH wire but don’t understand the CODE A, Code B, C, Parity. I need to hook this to my E38 for the park/neutral so OG/BK to the PCM and BK/WH to Ground (Please Confirm).
Can I use this switch to run an indicator light for Drive? I’m using a column shifter that was meant for a two speed powerglide so the standard PNRDL makes it hard to tell what gear you are in at times.
Does Code A mean while in P,R,L3,L2 you would have continuity between the OG/BK,BK/WH,TN/WH wires?
Code B While in R,N,D,L3 you would have continuity between OG/BK,BK/WH,YE wires?
Thanks in advance for the help,
Ron
Ron
The problem is using the switch for both TCM and a "Drive" light. With some glue and logic parts could get the appropriate output.
replace "code" with "bit" and it should make more sense - it's a logic table
A B C P
0 1 1 0 = Park
0 0 1 1 = Reverse
etc
Might be easier to modify the detent in the column
A B C P
0 1 1 0 = Park
0 0 1 1 = Reverse
etc
A B C P
0 1 1 0 = Park
0 0 1 1 = Reverse
etc
A B C P
0 1 1 0 = Park
0 0 1 1 = Reverse
etc
Again Thanks
