93 camaro V6 swap to 2000 LS1
Old 02-26-2013, 09:15 PM
ReneC's Avatar
Default 93 camaro V6 swap to 2000 LS1
New member here need help with wire harness if someone has the wire diagram or pictures your help will be greatly appreciated ! Thank you
Old 02-26-2013, 09:34 PM
LS1Tech Sponsor
BP Automotive's Avatar
There are a lot of differences in the harness. Do you have the lsx harness? Are you going to try and use your harness?
FWIW we build plug and play harnesses for Fbody cars that include the factory firewall grommet, GM color codes, optimized routings, and all the needed parts to complete the install!
__________________
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
Old 02-26-2013, 10:01 PM
ReneC's Avatar
I want to use the stock harness Thanks
Old 02-26-2013, 11:01 PM
LS1Tech Sponsor
If your wanting to use your stock lt1 harness, you will have to add in what you need, repin the pcm connectors for a ls1 pcm, and relocate the map, idle air control, and tps.
__________________
1-888-467-4491
Old 02-26-2013, 11:13 PM
ReneC's Avatar
It's a V6 camaro 3.4 I have the ls1 stock harness
Old 02-26-2013, 11:17 PM
LS1Tech Sponsor
The easiest thing for you to do is to purchase an alldata diy subscription for both the donor vehicle and your 93. You can get both for under $50.
You will have to repin and extend some things.
__________________
1-888-467-4491
Old 02-26-2013, 11:27 PM
ReneC's Avatar
Thanks ! but somebody out there knows what I'm looking for
Old 02-27-2013, 09:39 AM
Strokinit383's Avatar
There are numerous threads on here that have what youre looking for. Try a search and you should find most everything you need. I've been in your shoes - 3.4 > Turbo 5.3. Just takes time and research. Good luck.
Quick Reply: 93 camaro V6 swap to 2000 LS1
