autometer. gauges
Old 03-02-2013, 08:03 AM
LsoneGT's Avatar
Default autometer. gauges
I ordered a oil pressure and water temp gauge, bot electric. Well go figure neither come with fittings that fit the ls1. For some ungodly reason autometer is closed on Saturday so no help from them. What do I need to do? Any local solutions ie home depot or parts store fixes? Thanks
Old 03-02-2013, 08:10 AM
LS1Tech Sponsor
psiconversion's Avatar
Some people tap the passenger cylinder head to get the water temp gage to fit. If that is out of the question, you can mount the temp gage in the water pump by drilling and tapping 1/4-NPT.
Where are you putting the oil pressure, up top or down low by the filter?
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old 03-02-2013, 08:18 AM
LS1PUNK's Avatar
If I remember correctly this is what I used.
http://www.speedwaymotors.com/LS1-Wa...pter,8195.html
Old 03-02-2013, 09:23 AM
95civic2005's Avatar
That's what I bought as well. Have yet to hook my gauges up tho.
Old 03-02-2013, 10:20 AM
LsoneGT's Avatar
I was looking at that as well, will the oil sending unit fit in the original location
Old 03-02-2013, 10:59 AM
LS1Tech Sponsor
BP Automotive's Avatar
the port on the back of the engine is metric. You will have to adapt it or drill and tap it sir.
__________________
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
Old 03-02-2013, 11:26 AM
ls1nova71's Avatar
Depends on how much firewall clearance you have. The Autometer oil pressure sender is huge, so you will most likley need a couple of fittings, one to adapt to the correct threads, and some others to angle it away from the intake. Probably easier to use the big sender in the oil bypass block, but then you have to make sure it clears the exhaust. Nothing's ever easy!
Old 03-02-2013, 04:07 PM
sweetk30's Avatar
i have read of guys gutting the orignal oil sender and tap to 1/8th pipe .
also i used the adaptor from auto meter and the big can sender for my gauge . fits fine on my 5.3 with truck intake and also in my c-10 with motor back 1.25 " closer to firewall from stock .
as for temp i drilled / tapped h20 pump .
Old 03-02-2013, 04:37 PM
LsoneGT's Avatar
Is there any place better than the other for tapping the water pump?
Old 03-02-2013, 04:40 PM
79LS1FOX's Avatar
Default what i did
Thats what I did, gutted and re tapped but I'm using a manual gauge with AN fittings and hose.
Old 03-02-2013, 07:44 PM
1981TA's Avatar
I put a water temp sensor in the heater hose like in the mock-up picture below. All parts but the sensor came from Menards. You can also see a nice flat spot on the water pump to tap as well.
Quick Reply: autometer. gauges
