BMW e34 Touring LS1 swap (BMW 5 series wagon)
#41
I know you've already committed to the GTO oil pan but FYI Canton makes a nice front sump 4 baffle pan. the front sump is about 7" from front and about 14" wide.
I started with a GTO oil pan and it needed mods to get the engine crank pully behind an after market sway bar, so I jumped over to the Canton pan and just re-did my X-member.
In an 83 (never ending ) Supra swap.
I recently took a short drive in a 1997 M3 with a stock lq4 with Ls6 tune, t56 and long tube headers with 3.15 diff gears.
Lets just say the smile was stuck to my face for a few hours.
The guy who did the swap was working with JTR and stated he gets better mpg with 6.0, he started with a 5.3 and said he was very surprised with the MPG- IIRC it was around 20 city and 30 hwy for the 5.3.
Enjoy.
Enjoy.
#42
Now for the motor mounts, which will be more challenging because of the steering box. But there are solutions I can see in my head. Just need to get in there.
#43
Sub-scriiibed!
Great work so far!
Have you noticed any trans tunnel interference issues with the 4l60e?
Also are you planning on staying with 2-piece driveshaft or going to 1-piece design?
Great work so far!
#45
Tunnel clearance is tight, but I don't think there is any major interference. I can't exactly tell since the motor mounts and powertrain alignment is not done yet. I am sure the BAM (Big *** Mallet) will come out to play.
#46
It seems many of the guys with LS BMW's start with a one piece and then opt for the 2 piece. I am hoping to just have the front section of the stock M5 shaft modded.
#48
I worry about the one piece fitting through the hole in the rear subframe. The Bimmer 2-piece is tapered at the end to fit. it gets very skinny. Things like that make me contemplate adapting the stock unit.
#49
Started the motor mounts. I don't know why, but slotting plate i not much fun to me. Maybe its because I don't really have the right tool for it. If I had a milling machine it would probably not mind so much, butt to do this all by had is too much meticulous work for my personality.
Starting the driver's side plate.
Alignment was spot on.
Passenger side mounting plate slotted and ready for the mount to get built to it.
Next step is to put the motor back in the car and then start fabbing up the mounts. I may be modifing the cross member to have a platform to attach the mounts to, but I am not sure yet. The stock BMW fluid filled mounts are weak. I changed my last year, when I pull the engine theydumwere ripped.
#50
I got these really cheap on Amazon(via Jegs) They are very thin walled (not good), but I am going to use them for exhaust experimentation. I am looking to create a unique system that has high scavenging and an interesting exhaust note. I also have some weld els that I am going to build something with.
I looked in side the stock LS1 (Firebird) manifolds, and I was very disappointed in what looks to be poor flow opportunities. Welds that make the ports a lot smaller than they should be, as well as the potential for exhaust gases to back up into other ports, Especially on the driver's side.
#57
The notch in the crossmember was enough. I didn't need to notch the oil pan.
I am using poster board to mock mounts. I wrapped them around the tubing and creased to make the the shape of the rectangular tubing. This allows me to get things set up in 3D.
My daily drive decided to cough up its coolant via some unknown leaking source -- now I have to deal with that, which takes my energy way from the project Grrrrr!
#58
#59
A link to it on my site.
http://www.classicdaily.net/category/past/e34wagon/
#60
I didn't...wasn't running a ton of boost. 10psi is fine on stock head gasket and compression. As long as you have a good tune. It made around 345hp when I dynoed it.
Great site!
