5.3 to 350 trans ???
Old 03-13-2013, 10:46 PM
jaywill's Avatar
Default 5.3 to 350 trans ???
What all do I need to do this and could you give part numbers ???
Old 03-13-2013, 11:47 PM
Chiropaul's Avatar
https://ls1tech.com/forums/automatic...0r4-4l60e.html
Old 03-14-2013, 03:23 AM
jaywill's Avatar
Thanks a lot !!!
Old 03-14-2013, 11:20 AM
jaywill's Avatar
can i use this 1 ???
http://www.summitracing.com/parts/at...make/chevrolet
or this 1 ???
http://www.summitracing.com/parts/bm...make/chevrolet
Old 03-18-2013, 09:14 PM
jaywill's Avatar
Default This is what i got 2day
I CAN BOLT IT UP JUST LIKE IT IS RIGHT ??? TC BOLTS DO NOT NEED 2 BE DRILLED ??? IT'S 11.5 BP...
Old 03-19-2013, 04:58 AM
99VetteFRC's Avatar
Yes, TC bolts need to be elongated, the converter bolt pattern is smaller. I used a die grinder and slotted holes about 5/16".
Old 03-19-2013, 08:46 AM
Beanslsxnova's Avatar
The easiest way to tell is take you tourqe converter and set it on the flex plate and see if they line up. My th400 converter bolted right up. I din't have to elongate any wholes on my 4l80 flex plate.
Old 03-19-2013, 08:47 AM
The easiest way to tell is take you tourqe converter and set it on the flex plate and see if they line up. My th400 converter bolted right up. I din't have to elongate any holes on my 4l80 flex plate.
Old 03-19-2013, 01:14 PM
jaywill's Avatar
This is the flate plate so the bolt pattern is 11.5. so a 11.5 converter will bolt right up...
Quick Reply: 5.3 to 350 trans ???
