LS 2 6 pin TB to 8 pin harness
Old 03-15-2013, 06:27 PM
LS79CAMARO's Avatar
Default LS 2 6 pin TB to 8 pin harness
Like the title says I'm putting an TBSS intake and TB on my engine, the TB has 6 pins and the harness, 04 5.3 harness has 8 pins. Does anybody know which wires I need to re-pin the connector or where I can get an adapter harness?
Old 03-16-2013, 08:20 AM
LS79CAMARO's Avatar
Can anyone provide wiring diagrams for either of the 2 so I can try to figure out which wires go where? Thanks
Old 03-16-2013, 08:34 AM
LS79CAMARO's Avatar
Thank you.
Old 03-16-2013, 10:17 AM
LS79CAMARO's Avatar
Excellent, thank you for the info. Do you sell the 6 pin connector I need? I found the connector in your eBay store. Can you sell me the relay/fuse panel and 6 pin connector please?
Old 03-16-2013, 10:41 AM
LS79CAMARO's Avatar
Bare connector works, this way I can pull the wires from my 8 pin harness and use the 6 pin. How about the relay/fuse panel you use in your LS harness, I am interested in that too. You can PM me if you don't want to put it on here
Old 04-05-2013, 06:00 PM
luisdavid11's Avatar
would this kit work for a 87mm truck tb off a 08 going into a 06 harness? thanks.
Old 04-06-2013, 07:49 AM
LS79CAMARO's Avatar
Depends on what your harness and tb look like
Old 08-26-2013, 08:12 PM
Blackpony's Avatar
I have an 05 harness with the 8 pin tb right now. It runs and drives fine, just looking to upgrade to the larger 90mm 6 pin tb along with an edelbrock intake. What else is required for this swap? Tb, tac, and pedal or can I use my current truck pedal and tac module?
The following users liked this post:
Nicholas Dargaville (12-22-2020)
Old 08-26-2013, 09:08 PM
Blackpony's Avatar
Do you have any experience with doing this? I am willing to try just curious about the tac and pedal.
Old 12-12-2017, 09:40 AM
Venomous281's Avatar
Did anyone ever figure anything out?
Old 12-13-2017, 04:55 AM
SheepDog209's Avatar
I think this might be what you need. I called PSI for my swap harness. I'm going with an LS3 intake on an LQ4. It's a 6-8 pin harness.
It's the torque rush x-link. It's a little pricey, but I was told it does the trick.
http://www.torquerush.com/x-link.html
Old 12-13-2017, 06:49 AM
MuhThugga's Avatar
Holy **** is that a lot of coin.
Old 12-13-2017, 03:38 PM
I wasn't happy about it. But when you need it, you need it.
Old 02-25-2020, 04:03 PM
Dave Reed's Avatar
Default LS 2 6 pin TB to 8 pin Harness
can you provide me with the answers to your 2013 post above
Old 02-25-2020, 05:45 PM
Received 3,021 Likes on 2,352 Posts
No, because he hasn't been here in over 2 years.
Old 02-25-2020, 08:57 PM
My understanding is/was that you need this. Unfortunately my car has spent the last year and a half in the shop getting done work done and hasn't been fired up yet. Hope that helps.
http://torquerush.com/x-link.html
Old 05-12-2020, 08:29 AM
Jamie Culpepper's Avatar
Default Snake eater
I just got an email from snake eater. They used to make a retrofit throttle body but “it wasn’t popular” so they quit making it
Quick Reply: LS 2 6 pin TB to 8 pin harness
