Help crank pulley bolt won't loosen
Can I use a torch on the bolt without hurting gaskets, I put a wrench through the flywheel and a breaker bar on the bolt and it will not move.
Having the crack locked so it will not turn or flex at all helps a bunch. I sell a tool for this.
https://ls1tech.com/forums/parts-cla...e-holders.html
Then a good impact or breaker bar.
Tim
Tim
I never had a problem with mine. I put a bolt through the flex plate and engine stand mounting arm with a 24" breaker bar and cheater bar as others mentioned. Sometimes when I remove lug nuts that the ""shops" over tighten with their impact, I use a 1/2" drive ratchet and my service jack. Put the ratchet wrench parallel with the ground and simply jack it up.
Get a bigger cheater pipe. I use the handle for my jack. Just make sure your hands are clear so you don't smash them if something breaks.
The "jack up the ratchet" trick works well for some things. I've use it for tie rod jam nuts and other assorted suspension jobs, but never for a crank bolt.
If you have room, you can try using the starter. Wedge the breaker bar against the frame or shop floor, pull the ECM fuses to keep it from firing, and bump the key a couple times. Its worked well for me on other engines. Be careful not to put the bar through the radiator/hood/roof/fender/etc.
I'll try again soon.....
Pulley Removal
I used a puller from O'Reilly. The Chrysler one worked great. Rent for free or buy for $50. I needed to add a spaced between the end of the bolt and the bottom of the crank bolt hole, turned right off.
Good luck.
Good luck.
If you rent a puller, get one with a torrington bearing in the kit. It will make re-installing the pulley much easier and you won't have to worry about pulling the threads out of your crankshaft. Slip it over the head of the new crank bolt and the pulley will slide right on.
